Originally Posted by EmmBeeDee
Well we've got our TT on the road now and it is very impressive, though the gearing's a little strange. In my workshop manual it says that we should have 42/15 tooth sprockets but it has a new set of AFAM in 43/14, so it has a lot of acceleration but is revving fairly high on the highway. We've ordered a 16 for the front to see what we think of that. Is this a good idea?
The rear brake pedal is a bit too high, but there seems to be some adjustment possible in the clevis on the threaded shaft. Can we just move the pedal down by shifting the clevis higher up the threaded rod? I looked in my factory manual and there's nothing in there about adjusting the pedal height.
Thanks in advance for any help with this.
Mike
Regarding gearing: it should be either 14/42 or 15/45 stock (1:3) 16/43 (1:26785) will be way too tall. A lot of us on here have 15/47 (1:31333)set ups that have more acceleration than stock and a higher top speed. I'd probably leave your sprockets as they are since its just between stock and 15/47 ratio.
Not sure on the rear brake pedal, I'd like to angle mine down a little too but I didn't see a way to adjust it.
