Low idle, stalling '04 Daytona
As the title says, sometimes starts fine, sometimes takes a few seconds after it sits few days, warms up at 2000+ rpm, once completely warm might stall at a stop, not always. Started suddenly, no warning lights, no hesitation, was on a lengthy ride and it stalled at the light, that was late last fall. I parked it for the winter, in the spring changed the gas, installed new battery, went for a ride, same problem. I did few thousand miles this year and this has not gone away, I've been to busy to look for answers till I stumbled on this forum. Hope someone has an answer
Installed new plugs (cause I had the tank off) the idle servo seems to work, it moves and so does the secondary butterfly (choke?) when ignition is cycled on. Are there any multimeter tests? TPS, etc?
Appreciate any help!
Dmitry
**EDIT**
I did read the "Stalling" thread in the technical thread compendium and it suggests installing new map.
This seems more like a component failure as it just happened...
