hints needed for seized compression damping adjuster - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 08-26-2009, 01:56 PM   #1 (permalink)
thought i'd have a tweak of the suspension and annoyingly enough the last adjustment i made was to the compression adjuster at the bottom of the right fork leg...which was stuck solid.
i've tried heavy soaking with wd40 but so far no joy..and i'm reluctant to put too much force on it as it's only brass i think and it'll chew up pretty easily...
any suggestions/techinques to try???
johnnycactus is offline   Reply With Quote
Old 08-26-2009, 02:40 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
One of the comp adjusting screws on a set of used forks I purchased for the inner tubes was seized. I found that the steel retaining pin had seized the mess together. I eventually freed it after using a little heat and liquid wrench (or you could use another brand of penetrating oil). WD40 doesn't work so well as a penetrating oil.
Take a propane torch and hold the flame away from the metal, slightly heating the aluminum around the screw. Don't heat the screw as much as possible. The aluminum around the screw and down in the tube will expand faster than the brass screw and steel pin. You don't want to heat the aluminum very much, as there is a seal that can be damaged. Heating it to the point where it is on the high side of warm to the touch is about all I'd go. After the heat is applied, quickly shoot the penetrating oil around the screw and use a large, properly sized screwdriver to work the screw back and forth. Use steady pressure, but don't force the screw to the point of rounding off the head. Just keep working it back and forth, applying the oil. You could try this before adding heat, but the key is to use a screwdriver that fits snuggly to the bottom of the slot and as wide as possible.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 08-27-2009, 05:56 AM   #3 (permalink)
cheers bomb!
my next step was going to be a boiling kettle off water poured over a rag wrapped around the area and some proper penetrating fluid....seems to be along the same lines of thought!!
fingers crossed!!!
cheers!
Front compression or rebound damping question Blade929 Speed Triple Forum 7 05-29-2009 03:40 PM
Seized eccentric train adjuster Calzor_Suzay Sprint Forum 10 03-11-2009 05:58 PM
Compression dampening force adjuster screw stuck... Reppyboyo Triumph SuperSports 5 07-06-2007 03:54 PM
Hints needed on brake pad & fluid replacement triumphantguy Hinckley Classic Triples 2 03-09-2006 06:23 PM
S3 rebound/compression damping question teacherkeith Speed Triple Forum 5 08-11-2004 01:23 PM
