Motorcycle.com
Old 08-15-2007   #51 (permalink)
Favorite Bike: '06 Triumph Speed 4
Wow. Your bike either has some major engine work done or the dyno you used is optimistic (or both). If you dynoed 130hp, you're making something like 150hp at the crank.
Beer is proof that God loves us and wants us to be happy. -Benjamin Franklin
rustbucket is offline   Reply With Quote
Old 08-28-2007   #52 (permalink)
Favorite Bike: TT600
Other Motorcycle: 1997 zx7r
I like to know how you got the power out that bike. And where the dyno was done. If it was Mario at MD Cycles, then I would trust the numbers.
ukilme2 is offline   Reply With Quote
Old 08-29-2007   #53 (permalink)
Other Motorcycle: 675
Extra Motorcycle: If I must a Ninja 636
It was a Dyno in New York..We trailered it down..only time I have put it on a trailer. didn't want to drive it all the way down..
Thats A friend, A hot Friend but a Friend on the bike.
BritMan is offline   Reply With Quote
Old 12-30-2007   #54 (permalink)
i'm trying to set the rear shock preload but it seems i need a special tool for it (doesn't seem like the standard wrench type ring)
how did you guys change the preload on the rear shock?
Justice Strike is offline   Reply With Quote
Old 01-02-2008   #55 (permalink)
banda's Avatar
Standard wrench works ok, but there are a couple things that make it easier:
First, unweight the rear suspension - with the bike on its kickstand, use a small jack to carefully lever the rear wheel off the ground. The bike will be at an unnatural angle, but not too precarious to work on.
Second, don't bother with undoing the top lock collar separately from the bottom collar when removing preload - just turn them both together. Snug the top one down when you're done. It's much easier to turn them both together; they are too thin to turn them individually more than just a tiny bit.
banda is offline   Reply With Quote
Old 01-03-2008   #56 (permalink)
redl1nerpm's Avatar
Other Motorcycle: Past: ZX9R
i found these two pages useful if you dont know how to do it:
Haven't done it yet, but looks very easy
redl1nerpm is offline   Reply With Quote
Old 01-03-2008   #57 (permalink)
banda's Avatar
You'll notice that there is no mention in those pages of how to change the rear pre-load. This is arguably the most important adjustment, the one you do first. The owner's manual claims it is a procedure to be done by the authorized dealer.
Old 01-03-2008   #58 (permalink)
Favorite Bike: Very fast 675
Will's Avatar
You can also use a screwdriver and mallet to turn the collars. It isn't elegant, but it works.
Will
Old 01-03-2008   #59 (permalink)
redl1nerpm's Avatar
True, and nor does the service manual. Someone should probably chime in and explain how don't you think?
Old 01-03-2008   #60 (permalink)
Will's Avatar
Measure the height of a point on the bike while it is sitting on its wheels. Then measure again with the rider's complete weight on it. It will take two people to do this. Three makes it easier since you want ALL the rider's weight on the bike. Then you tighten the collars to add more spring tension and lessen sag, or loosen the collars to reduce spring tension and increase sag. You can make the adjustments by using a special wrench or using a long screwdriver and mallet. Both work.
Will
Suspension settings on 06 Jonny955 Tiger Workshop 5 06-24-2006 04:25 PM
Suspension Settings for 01 S3 SlvrSurfr Speed Triple Forum 1 04-07-2005 06:43 AM
Suspension settings LEDGERJIM Speed Triple Forum 6 11-22-2004 02:32 PM
suspension settings for two-up... dml955i Speed Triple Forum 1 06-17-2004 06:15 PM
suspension settings uptick Speed Triple Forum 4 04-06-2004 09:49 AM
