Old 03-29-2005   #31 (permalink)
Here's my settings:
Rear:
preload: 47mm treads showing
bound: .25 from full in
rebound: .50 from full in
Front:
preload: 1 line showing
Bound: .25 from full in
Rebound: .50 from full in
I weight 190 pounds, it feels very good at the track but pretty harsh on the street.
TTsixxer is offline   Reply With Quote
Old 03-29-2005   #32 (permalink)
Here's my settings:
Rear:
Front:
Old 09-04-2005   #33 (permalink)
I keep the front a little bit on the soft side because most of my roads are bumpy.
I also slid the fork tubed through the tripple clamps so 6mm of the fork tube (below the aluminum fork cap) is protruding above the handlebar mount. This helps the bike fall into tight corners, but gets a little wobbley under hard acceleration over bumps.
Almost nobody can keep up with me and I don't even try.
BoFax is offline   Reply With Quote
Old 11-13-2005   #34 (permalink)
Just tagging a post on this string to keep it current, because it is so useful for new S4 & tt owners
Jon G
[ This message was edited by: lcjohnny on 2006-05-02 15:21 ]
Old 11-13-2005   #35 (permalink)
*clapping* :upthumb:
Fast guys ride. Everyone else decorates.
WHAT is offline   Reply With Quote
Old 11-18-2005   #36 (permalink)
well a round of applause just makes me do it again
SO another post with no new information to keep this high information string available to new 4 cyl owners.
Will can this go in a knowledge base or something? :???:
Johannes von Grun
Old 11-18-2005   #37 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
I de-stickied it, but it looks like it is back by popular demand. It is getting re-stickied!
Will
SponsorHouse profile
Old 11-24-2005   #38 (permalink)
sgtrice
How would this setup be for someone weighing 200lbs. I just bought an 03 S4
Old 11-25-2005   #39 (permalink)
Will's Avatar
You probably want to add a bit more preload, but the rest of the settings should be OK.
Will
Old 04-30-2006   #40 (permalink)
ok for someone who has no owners manual wicj is the rebound and comp. settings adjustments i know where they are but which is which?
a baby seal walks into a club
midnight is offline   Reply With Quote
Suspension settings on 06 Jonny955 Tiger Workshop 5 06-24-2006 04:25 PM
Suspension Settings for 01 S3 SlvrSurfr Speed Triple Forum 1 04-07-2005 06:43 AM
Suspension settings LEDGERJIM Speed Triple Forum 6 11-22-2004 02:32 PM
suspension settings for two-up... dml955i Speed Triple Forum 1 06-17-2004 06:15 PM
suspension settings uptick Speed Triple Forum 4 04-06-2004 09:49 AM
