Not sure about different brands front/rear, but we'll see.
Big no no when it comes to mixing brands :-x
I know tyres/tires ain't cheap so if you can only afford to replace one, then stick the same type back on.
If you mix brands then you may well have 2 very different profiles which will give you all sorts of wierd handling probs.
I know people sometimes mix tyres from the same brand with the stickier one up front (ie 010 front 020 rear) but I have never tried it as i'd much rather have tyres that are matched to work together and share similar grip levels and profiles.
Then again, if you are some sort of riding God then you can probably stick any old ***** on it and still out-ride me :thump:
