charging issue on my d6
hi there!
I'm new here, I'm italian so please exmuse me for my bad english!
so, some days ago I left my bike for 2 hours with the lights on and my battery was completely drained...
started the bike ''pushing'' it, but no charging during 40km, I changed the battery, but no charge at alla, after 60km the new battery was ''empty'' and the bike started malfunctioning, I've read avery post here about mods and tests on the charging wirings....I tried everything but without any result, so:
my alternators voltage are 60V at 5000 rpm on every combination of the wires, so it's ok...
my r/r measured with a diode tester seems to work ok
my voltage on the battery plugs is:
12,4 with bike off
12,0 idleing
<12 revving
no charging voltage at all...
so I tried bypassing the oem wiring from the r/r to the battery with a 30A fuse on the +line but nothing changed...
the fuse I added is ok, tested with my multimeter it says 0 ohms...
cleaned the earth connection to the engine, nothing....
I noticed that wires are pretty hot but no output from the r/r...
I've just ordered a 2008 CBR 600 RR 's r/r that's a mosfet one to replace my one, thinking that the problem is there...
have you got any input and suggestion!?!?
thanksss!!!
