Changing chain/sprocket - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-01-2009, 12:48 PM   #1 (permalink)
Favourite Bike: Triumph 675
Other Motorcycle: Triumph TT600
Hey guys
The time has come for me to change the chain and sprocket on my
My loved bike.
But im not sure what tools i need. If anyone has the time to make one it would be much appreciated.
Some general tips and tricks and stuff i should think of?
jojye is offline   Reply With Quote
Old 07-01-2009, 02:06 PM   #2 (permalink)
Favourite Bike: 2000 TT600
27mm socket for the rear axle nut. 36mm (I THINK) for the front sprocket. Make sure to loosen that front sprocket nut before you cut the chain.
'00 TT600
'87 GN
GNTurbo6 is offline   Reply With Quote
Old 07-01-2009, 02:40 PM   #3 (permalink)
so i really need to cut the chain with a power tool?
Friend told me this but i didnt really belive him :/
Old 07-01-2009, 07:26 PM   #4 (permalink)
Favourite Bike: 2009 Sprint ST
Extra Motorcycle: Past: TT600, zx7r, GPZ750
You just need a dremel tool with a cutting wheel. You can usually get them really cheap if you do care about brand name or quality.
The front sprocket is 35 or 36- if someone can confirm this.
ukilme2 is offline   Reply With Quote
Old 07-01-2009, 07:39 PM   #5 (permalink)
dremel tool is def easier to get hold of! can anyone confirm the size of the front sprocket? Ill need to go pick it up at at HW store
Old 07-01-2009, 08:24 PM   #6 (permalink)
Yak
Yak's Avatar
If you are doing the whole thing ... Front/rear and chain
Start with the front sprocket. Its best to use the old chain to help break the nut loose on the front countershaft. These things are usually very tight, so you'll need a large breaker bar and a 36mm socket, a deep socket is best so your breaker bar clears the frame. You also need something like a wedge with a sharp point like a wood chisle to get underneith the folds of the safety tab washer and bend it back so the nut will turn.
Here is how I do it...
Stand on the right side of the bike, put one foot down on the rear break, reach over top of the seat and pull up on the breaker bar to loosen it. You can also put something in between the wheel spoke and the top of the swingarm like a hammer handle, piece of pipe, etc.. if you are having trouble holding the wheel with just the brake, but be carefull not to put it on top of the brake line. Like I said, these things can be super tight.
Also, depending on the chain you get and the masterlink you choose you might need a chain rivet/press tool. Whether you get a clip style link or a rivet style link, Id recommend getting a link press to press the plate on properly. Rivet tools can be pricey for a good one so the clip link is the "budget" option. Right now I'm running a clip style link and its holding up fine. (RK X-Ring Chain)
The rear sprocket is fairly self explanitory. Once the wheel is off the cush drive will basically pull apart and you can inspect the bearings and grease and the condition of the rubber blocks.
2005 Triumph Speed Four - Yellow
Yak is offline   Reply With Quote
Old 07-02-2009, 09:55 PM   #7 (permalink)
You will need a breaker bar. You can use a c-clip link but I would safety wired it and then use red gasket (comes in a tube) material to cover it. I did this with my track bike and never had an issue. Just check it very once in while.
Also, EK chain now has a master link that uses a 8mm wrench to press the links together. Therefore no tools are needed. I have used this on my TT600 and no issues as of yet.
Old 07-03-2009, 01:15 AM   #8 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
I really, really like air impact wrenches for front sprockets. It's got around 80 ft lbs of torque on it. You can get it apart with a bar and socket, but air is the lazy way out. It is a 36mm nut. Be sure to replace and bend up the washer when you put the front back on.
Will
SponsorHouse profile
Old 07-03-2009, 01:21 PM   #9 (permalink)
Got myslef the following items
JT 14/42 Sprockets
EK QX Rring 525 chain
3/4 Bar and 36mm Socket.
Rivet tool for the chainlock.
Friends got an angle grinder thet should make short work of the chain.
try doing the job tomorrow prolly be alot harder then im imagening so wish me luck
Old 07-04-2009, 02:48 PM   #10 (permalink)
well that sucked, the lock was not properly secured so the bike spit the chain off after about 2km luckly nothing easle happened. days work gone wasted yay
Changing Fork Oil & chain, sprocket? jixaw Triumph SuperSports 1 04-09-2008 02:31 PM
Changing the sprocket Blacklion50 Twins Technical Talk 1 05-17-2007 10:50 AM
chain and sprocket changing oldyeller Daytona Deliberations 7 11-11-2006 03:07 AM
sprocket changing and chain guard wear or not rckrzy1 Speed Triple Forum 0 07-24-2006 02:54 PM
Changing chain and sprocket-adjuster kelticwolv Sprint Forum 0 06-01-2005 11:45 PM
