Dead Daytona 600 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!New BonnevilleHonda Powersports
Old 06-05-2009, 11:27 AM   #1 (permalink)
Dead Daytona 600
I took my bike (Daytona 600) into a Triumph dealer to have the blinker worked on. Turns out it needed a new flasher relay and some wiring in the front right blinker. When I left the dealership with my bike I noticed the check engine light was on. I have seen the light come on before whenever a relay was pulled or battery was diconnected and it has went away after two rides so I just thought that that was the case. I got home and parked it in the garage for the weekend. However, a couple of days later I went to start up my bike and turned the key, nothing. No lights or battery power at all. I checked the battery terminals to make sure that they were tight and I got nothing. I told the dealer and of course they are like "We wouldnt have taken a bike out to you with a check engine light on." im waiting for them to call me back. Any of you guys have any idea what may have happened?
Sir Simothyno is offline   Reply With Quote
Old 06-10-2009, 11:04 AM   #2 (permalink)
Favourite Bike: tt600
have you tried trickle charging the battery? it may just need a recharge.
Parts I am currently looking for:
Daytona 600-650 passenger foot pegs
Daytona 600-650 bodywork over subframe - THANKS Agkistrodon
any muffler to go on a TT600, Speed Four, or anything that will fit. - Pending with HAP
chrisjames is offline   Reply With Quote
Old 06-10-2009, 02:58 PM   #3 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I would have turned around and taken it back to the dealer as soon as I saw the MIL tripped, as it is now your word against theirs. Sounds like a charging issue or the wiring loom is grounding out somewhere which is draining the battery. Have you checked the battery voltage?
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 08-15-2009, 10:43 AM   #4 (permalink)
was this ever fixed my daytona has died as well exactly same problem
zombieforever is offline   Reply With Quote
Old 08-15-2009, 11:01 AM   #5 (permalink)
Favourite Bike: Triumph Speed Four
Other Motorcycle: Yamaha TDM 900
Extra Motorcycle: Yamaha RXS100
Silly question, have you checked the fuse?
How appropriate, you fight like a cow.
chris-red is offline   Reply With Quote
Old 08-15-2009, 11:06 AM   #6 (permalink)
thanks for the reply - i have checked all the fuses yeah (5 next to battery, white one next to batt and the 4 at the front) and they are all ok. my alarm isnt getting any charge off the battery either, im charging up another battery i know works and ill try that one in case its a faulty battery, i had just put a new one in it reads 12.8v tho so im not holdin out too much hope on different batt
Wet, Dead '06 T-100 Hitch Twins Technical Talk 17 03-16-2008 06:49 PM
95 daytona 1200 dead Kingjoey5000 Daytona Deliberations 8 02-12-2008 01:43 AM
NH Togas-Will they wake the dead? (or almost dead) johnnyb84 Twins Technical Talk 32 01-15-2008 01:37 AM
Dead 595 Daytona gruff Daytona Deliberations 7 10-23-2007 12:35 AM
RS dead again jellero Sprint Forum 13 08-26-2006 11:35 AM
