How to adjust a throttle cable - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-31-2009, 03:36 AM   #1 (permalink)
Favourite Bike: Daytona 600
I've got about 1/4" free play in the throttle grip before it increases rpm above idle.
This is starting to cause me problems in corners. Racers seem to think this is a big deal. Some racers refuse to test ride a street bike before the throttle free play is eliminated.
Is this a normal factory adjustment, or do only racers do it?
dealsgapdragon is offline   Reply With Quote
Old 05-31-2009, 12:10 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Racing is different from riding on the street, so what racers like and want is often different from what's best on the street. The throttle free play is typically adjusted by fittings either inline on the cable housing near the clocks or right at the housing.
Will
SponsorHouse profile
Throttle cable help Malibu Twins Technical Talk 3 04-12-2008 02:48 PM
Clutch Cable Adjust RevDice Twins Technical Talk 8 08-19-2007 08:04 AM
small knurled screw to adjust clutch cable won't budge PtboSprintSt Sprint Forum 2 06-07-2006 12:38 AM
Throttle cable ??? 99 vs 02, 1x or 2x cable? robadele Sprint Forum 8 01-07-2005 08:25 PM
throttle cable TT Maintenance & Workshop Talk 2 06-20-2004 03:54 PM
