Tachometer and instrument panel bugs are usually signs of a faulty charging system/battery or, in the case of the speedometer, a bad speedo sensor. However, as StevieH pointed out, water in the electrical connections cause similar issues. I suggest first checking voltage at the battery terminals to see what is happening there. If that looks good, disconnect the instrument panel from the main wiring harness, blow it out with air, apply a little dielectric grease, and connect it back up.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
