I pay about $50 a gallon for Mobil 1 10w-40, so that's a little pricey. As for the above comment insinuating that Mobil 1 is somehow lesser quality, I'd like to see road tests showing this. I've seen tons of independent studies, and there isn't a super clear consensus on a superior oil. You can't go wrong with most of the fully synthetic oils.
As for how much oil the bike should take, it's around 4 Qts I believe. As stated, check the oil level when the bike is upright. It should be near the top hash marks. And yes, over filling is bad - don't let anyone convince you of otherwise.
