Front Suspension adjustment - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-18-2009, 03:40 PM   #1 (permalink)
Newbie
As you can see i am a newbie on here but would like to know how and what the official adjustments are for the front suspension as they are both uneven and the brass screws are in different places to one another and i was told they should both be in equal positions..any ideas ty
banksy1uk is offline   Reply With Quote
Old 05-18-2009, 04:03 PM   #2 (permalink)
Stampy's Avatar
You need to set your static/rider sag first that sets the preload for your weight, depending on your weight you might have to fit after market springs to get the proper front & rear sag
Then you can play around with your comp and rebound damping to suit your riding style. There is no one setting, what works for one person might not work for the next.
Stampy is offline   Reply With Quote
Old 05-19-2009, 12:44 AM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
The brass screws may or may not need to face the same direction. The upper fork legs can rotate when you install them, so if they were put in at different angles and tightened without being straightened, the screws would be different with the same adjustment. You should count the same number of "clicks" out from fully screwed in. There's information about all kinds of different adjustments floating around, but ultimately, it's all got to do with your specific riding style, habits, and preferences.
Will
SponsorHouse profile
suspension adjustment Kenwbrooks Tiger Workshop (archive) 4 06-05-2009 07:19 PM
Chain adjustment after suspension adjustment? Mochissmo Speed Triple Forum 1 10-13-2008 10:33 PM
675 Suspension adjustment? Beach Daytona675 Forum 3 01-08-2007 10:31 PM
Suspension Adjustment Silverado57 Twins Talk 0 06-13-2006 10:01 AM
Front suspension adjustment AVMECH Club Cafe' 1 03-03-2006 05:33 PM
