Ok guys, I need help. I've been working on this with a great deal of help from our local ratpack, but we've hit a dead end and cannot come up with a cost effective solution.
I'm in the process of replacing rings on all four pistons on my 04 Daytona 600 as I have a blowby problem on cylinder 4. I've pulled the head without any major hiccups but I am at the part now where I need to remove the cylinder liners. I don't have the triumph cylinder liner removal tool and do not intend to spend $250 to get one. I don't want to drop the engine and crack the case as that will put me way deeper into this than I'm comfortable. Here are pictures of what has been attempted thus far.
Using this expansion plug to stick in the cylinder:
This is the plug inside the cylinder:
The next to pictures show the rig that I'm using to pull the liner up. The cross bar is bending in this photo, but I've resolved that issue with a stronger cross bar.
After correcting the issue with the bending crossbar, I thought we had a solution, but then I found that instead of pulling the cylinder liner out, I was only pulling the plug out of the cylinder liner. I saw on another forum a suggestion that you could put gorilla tape on the inside of the liner then turn the crank and the piston would catch on the tape and push the liner up. This was not effective. I also tried lining the cylinder with gorilla tape to give extra grip to the expansion plug but that also did not work. Anyone have any ideas that may work on this?
