Blinker insanity Daytona 600! - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!New Bonneville
Old 05-15-2009, 01:21 AM   #1 (permalink)
I am trying to get the blinkers on my daytona 600 to work to no avail. I have all new bulbs, circuit breakers are good, I used a generic flasher (which could be the problem). Whenever I try to switch on either blinker there is absolutely no light on either side front or back. I took the flashers out from under the seat and tried to plug them into the front flasher mount (where I used the generic one) but it still didnt turn the blinkers on. The front flasher is a 5 prong, 12volt which is the kind of generic one I bought. Id rather not spend the $70 on a flasher from the dealer but I might be stuck. Thought Id ask you guys first.
Cheers,
Tim
Sir Simothyno is offline   Reply With Quote
Old 05-15-2009, 03:58 AM   #2 (permalink)
DEcosse's Avatar
Get the correct flasher for your application.
You don't need to buy from dealer
You can even get electronic relay from somehwere like superbrightlds for under $20.
Incidentally flasher is not a 5-pin relay.
T'Rat.net BOTM November 2009
Old 05-15-2009, 11:45 AM   #3 (permalink)
Thanks Decrosse! My bike doesnt have LED lights. Is this going to matter? how do I know which flasher is right for my bike (daytona 600)?
Old 05-15-2009, 12:09 PM   #4 (permalink)
DEcosse's Avatar
Electronic flasher will work for either incandescent or LED - either way.
All the Triumphs are same - you need a European application - same as BMW's incidentally.
http://www.superbrightleds.com/cgi-b...uct=CAR#FL-889
Select the CF13GL-02 from the pull down menu in the one with the pic of the red relay.
Back to your original post again - if you identified a relay position with a 5-pin relay that is NOT the flasher relay. You must have the wrong slot.
Old 05-15-2009, 12:12 PM   #5 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
As I recall, it's exactly the same part as for a VW Jetta or Golf. My memory is getting a bit murky, unfortunately.
Will
SponsorHouse profile
Old 05-15-2009, 12:23 PM   #6 (permalink)
Decosse thanks for your help. There is what seems to be an empty flasher socket behind the headlight of my bike and the blinker didnt work so I assumed that that was the place for the flasher. There are 4 other flasher looking pieces under the seat. I cant figure out which one controls the blinker. Im not too good at reading electrical diagrams but if you know where I can get one that would be great. Ill follow your advice on your last post and see what I come up with.
Old 05-15-2009, 04:35 PM   #7 (permalink)
DEcosse's Avatar
Where are you located?
Are you in the UK?
Do you have one headlight on in low beam and one on in main beam?
For some markets the bikes were shipped with those relay slots empty to have it work like that.
Filling the empty relay sockets with 5 pin relays will give you both headlights on.
I'm not that initimate with the little Daytona personally so can'tt tell you which position is the turn signal relay.
But I'm sure someone will jump in soon .......
Old 05-18-2009, 11:52 PM   #8 (permalink)
Im in the US
Need a beep for the blinker! 5bassman Twins Technical Talk 15 02-10-2008 02:50 PM
Insanity behind the wheel trashman Twins Talk 13 09-24-2007 10:15 PM
Blinker relocation Whitehurst Club Cafe' 4 12-11-2006 10:16 PM
02 Daytona resurrection: no blinker signal; relay(s)/wiring question Tweeek Daytona Deliberations 1 08-22-2006 10:15 AM
Joining the insanity FlyingScot Twins Talk 5 07-07-2006 07:59 AM
