TT600 shift lever - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleOntario TourismMotorcycle.comHonda Powersports Motorcycle.com Classifieds!
Old 05-12-2009, 07:55 PM   #1 (permalink)
Favourite Bike: 05 Concours
ncdave's Avatar
Other Motorcycle: 03 Buell XB9R
Extra Motorcycle: 01 Triumph TT600
TT600 shift lever
Anyone else have a loose shift lever on their TT600? I even ordered a new bolt becuase I thought that was the problem, but it seems that the bolt does not clamp it down tight enough to tighten on the shaft. it moves back and forth, but the teeth are engaged enough to keep it from slipping while shifting. ideas????
NCDave
05 Kawi Concours, 03 Buell XB9R, 01 Triumph TT600,
99 Honda Superhawk
www.bikepics.com/members/ncdave
ncdave is offline   Reply With Quote
Old 05-14-2009, 07:31 PM   #2 (permalink)
Favourite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
The teeth on the shifter (and probably the shaft too) wear out over time. And if your like me from the constant shifts into a non existant 7th gear.
What I did was:
1. replace the bolt , it had definatly stretched.
2. used a dremmel (or small file) to grind off the teeth on either side of the slot where the bolt goes.
3. used a small cut-off wheel to make the above mentioned slot wider.
Whats happening is as the teeth wear, you start to get slop in the shifter. Just tightening the bolt only stretches it because the teeth on either side of the slot pull up against their coresponding teeth on the shaft, stopping the clamping force from working all the way arounf the shaft.
Removing the first couple of teeth lets the force spread a little further around, but since the shifter is aluminium it stretches around the shaft and completely closes the gap before the shifter is completely tight.
So now using a cut-off wheel you need to make the slot wider so you can have more room to tighten the bolt.
Of course eventually the slop will come back and you'll need to do this all over again until the shifter break, but who knows how long the will take.
Used to do this once a year on my old kx250, until I replaced the shfter with a heavy duty steel one. But that opens up an entirely new batch of headaches.
kubbie
"I'll call you if you need me"
kubbie is offline   Reply With Quote
Old 05-15-2009, 10:11 AM   #3 (permalink)
ncdave's Avatar
Excellent idea....thanks!
Now why didn't I think of that!
NCDave
99 Honda Superhawk
Old 05-18-2009, 11:40 AM   #4 (permalink)
ncdave's Avatar
worked like a charm....thanks for the help!
NCDave
99 Honda Superhawk
Need a shift lever 2bugeyez Speed Triple Forum 0 03-19-2007 10:53 PM
NEED 955i shift lever nyburner Sprint Forum 0 08-13-2006 02:56 PM
Shift Lever Fitch Sprint Forum 1 06-06-2006 09:28 AM
shift lever- @!&$$&% Longshot92 Maintenance & Workshop Talk 5 11-11-2005 07:37 AM
Shift lever adjustment iscarian Speed Triple Forum 6 07-08-2004 07:09 AM
