Our bikes are fickle beasts. Mine is exactly the same as yours - warm ambient temp, starts no problem - cold ambient temp, needs a fraction of throttle until the temp display reads a number as oposed to "lo". It's either the idle CO or idle stepper valve (aka IAC valve) or both. You need your dealer to set the idle CO, or you need a Tuneboy (pricey) or a Dealertool (£70 GBP).
Andy
