Wouldn't this work? lsl alternative risers? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-09-2009, 11:51 AM   #1 (permalink)
Favourite Bike: 03 Green Four Speeder
IBsellin's Avatar
Thinking about going w/some fat mx bars. If you drill 2 holes in your triple tree, seems like you could bolt on a set of bars pretty easily. Under a $100, vs $300 for the lsl set up. I probably missing something though. Any input would be welcome!
IBsellin is offline   Reply With Quote
Old 05-09-2009, 02:06 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
It depends on what the underside of the top triple clamp looks like. If you can get a clean mounting surface, it would work. You'd need to be very accurate with aligning both clamps so that the bar is straight.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is online now   Reply With Quote
Old 05-09-2009, 06:27 PM   #3 (permalink)
DEcosse's Avatar
Note that the bolts in those are intended for rubber mounts on MX bikes.
Consequently they are long and have a long unthreaded shoulder on them, that will protrude quite a bit below the underside of the bottom clamp before you get to thread, requiring a thick spacer or stack of washers under the nut.
Like this (not mine!)
I had some std. M12 socket-cap bolts machined with flats on them, to replicate the shape of the special ProTaper heads.
(you may be able to do this with a file or bench grinder)
Just take the flat down to flush with the shoulder diameter of the shank.
T'Rat.net BOTM November 2009
Old 05-09-2009, 06:34 PM   #4 (permalink)
IBsellin's Avatar
Thank you.
Thanks, that's what I was looking for. Little drilling, couple extra washers/nuts, I'm in business.
Old 05-09-2009, 07:34 PM   #5 (permalink)
I'd go with what DEcosse says personally. Get some shorter Allen bolts and grind/file the flats. You can by the raw steel ones and paint them, or you can get stainless ones. I think that would look much better than having nuts hanging off the bottom due to overly-long bolts.
Oil Alternative Hollymonster Twins Technical Talk 21 11-06-2008 02:07 PM
2000 Adventurer needs new motor? Will Trident motor work without too much work? carsandcigars Hinckley Classic Triples 13 08-21-2008 01:41 PM
Triumph risers vs. Gen Mar risers vs. 07 handlebars Vox Sprint Forum 25 01-30-2008 03:03 AM
Alternative grips doctordee Tiger Mods & Bolt-Ons (archive) 4 01-25-2007 05:17 PM
CRG alternative 805triple Speed Triple Forum 9 11-10-2006 01:10 PM
