I don't know off the top of my head, but my guess is you lost the blinker relay. I can't see from the photo, but if the connector has three slots for knife connectors at right angles, I'd bet dollars to doughnuts you lost the relay. They are cheap from an auto parts house. If you use LEDs, you will need to use an electronic relay or it will blink rapidly. I'm not sure how may different varieties there are, but I'm pretty sure you will find what you need. I recall something about using one intended for a Volkswagen, but it might be some other relay. I hope a better informed person can pipe up to correct me if I've just sent you down a rabbit hole.
Will
SponsorHouse profile
