Motor questions - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-25-2009, 02:12 PM   #1 (permalink)
Motor questions
Heres the deal. My 2000 tt600 bent a vavle due to the owners before me not doing maintance. So what should i do? its hard to find tt parts so any ideas? should i put in a S4 motor i know they have a better mid range from what i read. Are the cams the only differnce? Are S4 parts just as hard to find?
freshusmc is offline   Reply With Quote
Old 04-25-2009, 03:46 PM   #2 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
The only difference in the engines, mechanically, is the cams. S4 cams do have more midrange power, but TT600s have better torque. From my experience, there is really no difference in part availability. What does the piston look like? If it is not badly damaged, I'd be tempted to find a used head before getting another engine.
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 04-25-2009, 05:47 PM   #3 (permalink)
i just dropped the motor out and will proably open it up tomorrow and sometime this week.
Old 04-25-2009, 07:13 PM   #4 (permalink)
Favourite Bike: 06 Sprint
kubbie's Avatar
Other Motorcycle: 00 TT600
a little heads up.
if you replace the head you might want to check the connecting rod as well.
my dads a mechanic and told me the same thing when my tt dropped a valve.
granted the engine had alot of other damage anyway but it was bent. you could just barely see it so it had to be bad.
if it was a hard contact, double check the cam chain, mine stretched alot.
all total i spent somewhere near $800 putting it back to gether
good luck
kubbie
"I'll call you if you need me"
kubbie is online now   Reply With Quote
Old 04-26-2009, 01:08 PM   #5 (permalink)
any good places to order parts?
Old 04-26-2009, 01:41 PM   #6 (permalink)
The only place you are going to find parts for the internal is through a dealership or bikebandit.com. TRat.net members get a 10% discount at bikebandit, so that is your cheapest place to get gaskets and any other hard parts parts like a cam chain.
Old 04-26-2009, 01:56 PM   #7 (permalink)
is there a code or anything i have to use?
Old 04-26-2009, 02:57 PM   #8 (permalink)
Because of your question and others', this sticky thread has been created. Let us know how it goes. Discounts Thread
Old 04-26-2009, 03:48 PM   #9 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Originally Posted by kubbie View Post
a little heads up.
Good point. A connecting rod coming apart is what killed my 2001. They do indeed fail.
Will
SponsorHouse profile
What Motor? jm06bonnie Club Cafe' 3 02-11-2009 05:30 PM
2000 Adventurer needs new motor? Will Trident motor work without too much work? carsandcigars Hinckley Classic Triples 13 08-21-2008 01:41 PM
Oz Motor Gp - Oct 13/14 harrya13 Sprint Forum 0 07-24-2007 12:49 AM
Looking for a motor.... GrayMitchell Classic, Vintage & Veteran 20 05-09-2007 09:10 PM
How much motor oil? MrEd Speed Triple Forum 2 06-23-2005 11:14 PM
