TT600 Cold idle problems - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Old 04-22-2009, 08:26 AM   #1 (permalink)
Question TT600 Cold idle problems
I have a TT600 with an open road legal pipe, K&N and tuneboy.
Up until recently i had been using map 91 (Silver frame open pipe map) but after having an assessed ride the guy following said it was beltching out unburnt fuel, and it did smell rich at times. However the idle was fine (If bloody lumpy) and the warmup idle was fine.
I decided to use map 115 (the last tt600 map) which really made the bike fuel nice. I have upped the idle stepper and the idle fuel richness and when warm the bike idles and run's like a dream.
The problem is with the cold warm up process. It seems to always look for the same idle level no matter what the temp of the engine. This means that it will stall when cold, but then gradually improve as the engine warms up.
I have adjusted the target idle to a fairly high figure but this seems to make no difference and i am loathed to touch the idle stepper or richness as the bike runs superb when warm.
Is there anything on the bike which could be faulty that controls the warmup process, or is there something else to look at?
Thanks in advance.
scotthubbard is offline   Reply With Quote
Old 04-22-2009, 01:56 PM   #2 (permalink)
Favourite Bike: 2000 TT600
What temperature is it where you are when you're trying to start it? In my experience, my bike needs some throttle to let it warm up when its below 50F.
'00 TT600
'87 GN
GNTurbo6 is offline   Reply With Quote
Old 04-23-2009, 12:30 AM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
It shouldn't need any throttle at all to idle while warming up.
Will
SponsorHouse profile
Old 04-23-2009, 03:08 AM   #4 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I'm not sure what you adjusted to get the engine to stall on cold start, but have you tweaked with the cold start air/fuel ratios? You might have the start-up mixture too lean or the CO too lean.
You certainly don't want to touch the throttle when firing the engine, as this can throw the throttle position off.
Are the battery leads tight at the terminals?
As for what the person behind you said, they would not have been able to see unburned fuel. If they mean that there was black smoke coming out the exhaust, it could mean two things: the engine is running rich with too much fuel in the chamber, carboning things up and fouling the plug; or the engine is running on the rich side (not enough to foul the plug as the above situation) and has not been ran hard in a while. It can be carboned up and in need of a good run to clean it out. It is better to have a slightly rich mixture than lean, as a lean mixture can lead to major issues.
"My life stood-a Loaded Gun- / In Corners-till a Day / The Owner passed-identified- / And carried Me away- /. . .Though I than He-may longer live / He longer must-than I- / For I have but the power to kill, / Without-the power to die-" E.Dickinson
BombFactory is offline   Reply With Quote
Old 04-23-2009, 06:23 AM   #5 (permalink)
cheers for the replies. the guy following me was a police rider so he stayed quite close and basically said he was being gassed by the unburnt coming out of the pipe. idled like a lawnmower too. definitely no decoke needed.
the bike runs like a peach now on 115 but will not idle until 50 degree c. will then get progressively smoother til normal temp (80 d c). basically just will not adjust the idle to reflect cold start.
i've not adjusted anything from map 115 except idle stepper and idle richness (from sensor screen not map) and idle speed target from the map.
the wierd thing is that everyone recommends this map for all bikes so this can't be normal.
Old 04-23-2009, 11:19 AM   #6 (permalink)
What map is 115; they changed map numbering at one point, and my tuneboy maps aren't matching up to any 115. What Model is it from, VIN number range, and type of muffler?
Old 04-23-2009, 11:30 AM   #7 (permalink)
My bike is a 2001 silver framed bike. The 2 maps for this bike are 10090 & 10091. I am using a K&N and scorpion open pipe so i should be using 10091.
Triumph released one last map, i thought it was 10115 but could be 10165, which most people recommend is the best for all bikes. I know Will personally recommended this map to me some time ago.
The map itself is great and so much better/smoother then 10091 but where 10091 will warm the bike on idle, 165 won't.
These bikes sure do have 'character'!
Old 04-23-2009, 04:23 PM   #8 (permalink)
Will's Avatar
10115 is the 2002 and later map for TT600s. Beats me what it's called now. It was 10105 for a while, then something changed and it became 10115. Now it's something else. It's essentially the same map. I better just start looking for another TT600 so I can keep up!
Will
Old 04-23-2009, 08:22 PM   #9 (permalink)
Okay, I believe the 10115 is now the 10165. That is the late model map for a standard muffler engine equipped with secondary air injection. It is a popular tune, but at least from what I can find in my folders and from what I remember of TuneBoy's website, they don't have a late model map designated for aftermarket exhaust.
Old 04-24-2009, 12:26 PM   #10 (permalink)
Will's Avatar
No, they don't. The late model map was pretty much standard issue for all bikes as far as a jumping off point for custom maps. I don't know why the later stock can map works best, but it does in most cases.
Will
Bike's Cold Idle is low, warmed up idle is OK GleaminTwin Classic, Vintage & Veteran 5 05-25-2008 10:24 PM
TT600 running problems from cold? Mr OCD Triumph SuperSports 4 11-08-2007 08:51 AM
TT600 COLD START PROBLEMS tt600phil Triumph SuperSports 13 11-13-2006 09:29 PM
TT600 COLD START PROBLEMS tt600phil Maintenance & Workshop Talk 2 11-10-2006 08:21 PM
Idle Problems... Idle Adjustment.... Toystoretom The Rocket Science Forum 31 04-10-2006 01:30 PM
