Fuel EJECTION - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-21-2009, 12:42 PM   #1 (permalink)
Fuel EJECTION
Yes the title is right EJECTION
I have a 2002 Speed Four, that overnight has developed a fault, where it is ejecting about 30 miles worth of fuel per tank out of the exhaust
Its been to 2 main dealers who both said its number 3 cylinder with the valves not closing
I stripped and rebuilt the engine and found zero problems with the valves
I put new plugs in and checked the coils all of which are fine
Ive just ordered a replacement IACV as mine has definately packed in as the insides have fell apart
I know the IACV controls the choke and wondered if this was the cause, but the bike runs as sweet as anything, no high revving, no hunting for fuel or anything
anyone got any more ideas what could cause it??
guyver1 is offline   Reply With Quote
Old 04-23-2009, 12:27 AM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
I don't know what else it could be, but if the bike runs fine, I doubt it's the IACV. But, if you didn't find anything else wrong, I guess maybe it could be.
Will
SponsorHouse profile
Old 04-23-2009, 03:26 AM   #3 (permalink)
Favourite Bike: '02 CE Speedtona 955i
BombFactory's Avatar
I can't see how anyone would have thought the problem was valves. If there was something drastically wrong with the cams and/or springs to keep the valves open to use that much fuel, the piston would have had a hole blown in it long before you noticed a decrease in MPG. Also, the engine would run like absolute junk, backfiring out the intake and having no compression in that cylinder.
As Will said, if the engine idles and runs great, I can't see how it would be the IACV.
Have you checked to see that there aren't injectors sticking open? What did the old plugs look like, and what did the pistons and combustion chambers in the head look like?
The Resurrection: ’02 CE Speedtona w/GSXR Forks
The Reviving: Speed-TT Project
"When I reflect upon the number of disagreeable people who I know have gone to a better world, I am moved to lead a different life." - Pudd'nhead Wilson
BombFactory is offline   Reply With Quote
Old 04-23-2009, 04:41 AM   #4 (permalink)
Favourite Bike: Triumph Speed Four
Other Motorcycle: Honda RS 250
I think I'm having a similar problem. The bike runs fine, but the fuel consumption is appalling. Haven't had the head off, but the plugs are black-ish. Sometimes when starting it fouls a plug. It seems to be running really rich, judging by the smell of gasoline at the exhaust. I had a dyno tunder PC map, which I adjusted quite a bit leaner, but it didn't change a lot. Now I've bought a professional quality AFR meter, I'll have to install it and see what it says.
FART FYRA
pete2 is offline   Reply With Quote
Old 04-23-2009, 08:57 AM   #5 (permalink)
Cheers for replies everyone
quick update
I bought an OBD reader as my car through up a fault the other night, I took a chance and tried it on the bike
I got 3 codes which all pointed to the IACV
I fitted a new one just, and bike is running fine and idles a lot better, the faults are now cleared
so IACV was a certain problem part
The head was spotless on all valve openings and the valves were all fine too except 1 of them which had a minute black spot on it which came off when i reground all the valves
the valve gaps were all within tolerance, some high some low, but nothing to really moan about, the bike still stinks of fuel and exhaust fumes are wet and black
NO oil loss and NO coolant loss
I have no more dealers i can trust to look at my bike so im stuck
can the throttle bodies go out much on there own??
Old 04-23-2009, 09:53 AM   #6 (permalink)
Favourite Bike: '03 Speed Four (deceased)
Other Motorcycle: '08 KTM 690 SM
Is the temp sensor reading something sensible? They can get shorted out and read either very high or very low, the latter making it run rich and lumpy.
themaster is offline   Reply With Quote
Old 04-23-2009, 09:55 AM   #7 (permalink)
temp is fine mate
Old 04-23-2009, 04:21 PM   #8 (permalink)
Will's Avatar
OK, I suspect a mapping issue now. It's not a huge deal, since you are riding a Speed 4 and there just aren't too many maps for them. The California air injection map seems to work pretty well for a whole lot of people. Once you have a map you like loaded, then start lowering the fuel idle trim. There's a balance on these machines between leaning it out to the point it's a PITA to ride and having it puke fuel all the time. Since you had a screwed up IACV, the chances your fuel idle trim is all screwed up is about 100%. I'm assuming you have TuneEdit with all this. If you don't then you'll have a trip to the dealer ahead of you, and they SHOULD adjust the CO properly. Another thing which will waste a whole lot of fuel is throttle bodies out of synch. So there's another adjustment which you probably are in need of. Beats me why the inside of your motor wasn't all carboned up. For what it's worth, my TT600 would get less than 20 miles per US gallon at the track, so if you are really whipping it, you'll see lousy fuel mileage even if it's perfect.
Will
Old 04-23-2009, 04:45 PM   #9 (permalink)
only 1 map in the UK for the speed four, and thats bang on
tuneEdit i've not heard of before, but ive just ordered a dealertool (www.dealertool.co.uk) and that runs a check on pretty much everything on the bike, and tells you in a nice laptop display about your throttle bodies
if there out, the MOT is due next week so ill get them to adjust them for me then
Ive got a sneaky feeling the valve clearances are out
Old 04-26-2009, 04:50 PM   #10 (permalink)
quick update
Ive checked the valve claearances and found that 9 out of 16 were out
mostly by a tiny amount, but did find 2 that were out by .5 and .7 which is a hell of a lot
ordered new shims and will get them fitted, then try the Dealertool to see how the throttle bodies are
I feel I'm getting close now LOL
Quick-Disconnect Fuel Fittings and Rear Hinged Fuel Tank dealsgapdragon Maintenance & Workshop Talk 0 04-05-2009 01:42 PM
Question about the fuel connectors attached to the fuel pump mounting plate zapata Speed Triple Forum 2 11-16-2008 11:11 PM
Fuel Gauge Low Fuel Light problem any ideas ? CYNCRZR Sprint Forum 4 06-10-2007 12:36 AM
Fuel Tank paint clogging fuel filters on Adventurer Hinckley Classic Triples 3 03-09-2005 04:41 PM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 10:23 AM
