oil level warning light - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 03-28-2009, 01:37 PM Thread Starter
Main Motorcycle: Kawasaki Z1000
Hi there i have a 2004 triumph daytona 650 and i went out to start my bike this morning and it was telling me that my oil level was low. quick check of the level and it was fine if anything maybe a little to much. does any one know if it could just be sensor? took it out and cleaned it and made sure the connection was fine.
Any help would be much appreciated.
stevos is offline
post #2 of 9 (permalink) Old 03-28-2009, 04:12 PM
The light is actually for low oil pressure not low level. Has the bike fallen over on that side?
2003 Speed Four
BudGT is offline
post #3 of 9 (permalink) Old 03-28-2009, 05:29 PM Thread Starter
Its not the oil lite that lights up. when i turn on the ignition on the digital display says "oil low". The oil light light comes on then goes off but the low oil warning message is there until you start the bike.
stevos is offline
post #4 of 9 (permalink) Old 03-28-2009, 06:12 PM
Main Motorcycle: 07 Speed Triple
Other Motorcycle: 08 Sprint ST
Extra Motorcycle: T595 Daytona
Does the display say"Lo"?
I recall my S4 did this until the temperature went up enough to register acurately, in which case it's normal.
S3Partisan is offline
post #5 of 9 (permalink) Old 03-28-2009, 06:12 PM
I don't know about the D650, but on my Speed 4 the only reference to "low" anything on start up is temperature until it warms up.
Sorry I couldn't be more help.
2003 Speed Four
BudGT is offline
post #6 of 9 (permalink) Old 03-28-2009, 06:21 PM Thread Starter
Its definatly telling me low oil and the little oil can flashes. once i start the bike it goes away and the word low is there but i know this means low oil temperature. My problem is when i turn on the ignition it says oil low and the can flashes.
stevos is offline
post #7 of 9 (permalink) Old 03-28-2009, 08:47 PM
Main Motorcycle: '02 CE Speedtona 955i
BombFactory's Avatar
What you're talking about is normal. When the ignition and kill switch are turned on, the MIL and oil pressure lights should illuminate and the digital screen should say 'Lo" until the coolant temperature reaches 120+F. The 'Lo' only refers to coolant temp, not oil volume--as other members have already said. The only oil sensor on the engine is for pressure. If there was an oil level sensor, the oil level warning light would go off every time the bike was put into a turn and leaned over.
If the MIL and oil pressure lights go out once the engine is started, and the 'Lo' turns into a numerical reading once the engine warms up, there is nothing wrong. Your owner's manual explains all of this.
I have no spur
To prick the sides of my intent, but only
Vaulting ambition, which o'erleaps itself
And falls on the other. -Macbeth knew
I.VII
BombFactory is offline
post #8 of 9 (permalink) Old 03-28-2009, 09:25 PM
El Moderatore
Main Motorcycle: 2007 Bonneville
Calliway's Avatar
Other Motorcycle: 2007 Kawasaki Versys
Yeah and the temperature has nothing to do with the oil. It's engine temperature which is monitored by the coolant temperature switch.
Calliway is offline
post #9 of 9 (permalink) Old 03-29-2009, 08:46 AM Thread Starter
Ok guys thanks for the help must have been reading it wrong just got a bit confused about it with the oil can flashing. will have another look at it today.
stevos is offline
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 9 05-23-2014 05:53 AM
oil warning light the_beast Tiger Chat 1 04-26-2008 04:12 PM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 09:18 AM
ECU warning light TorqueyT Tiger Chat 14 04-17-2005 06:31 PM
Oil pressure light/oil level pigpen955 Tiger Workshop (archive) 5 03-16-2005 09:09 PM
