Poor MPG, oily smell from exhaust and compression test. - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
 3Likes
post #11 of 20 (permalink) Old 04-13-2017, 04:24 PM Thread Starter
Main Motorcycle: 2006 Tiger '955
Anyone think it's worth putting a new O2 sensor on it, see if that brings the MPG up a bit ??
Safe riding.
Regards,
Graeme.
Tiger-G is online now
post #12 of 20 (permalink) Old 04-13-2017, 04:26 PM
tiny tiger's Avatar
I would only if I could see what the current o2 is reading. I'm not sure if tune ecu can, but I think it does read the o2. Maybe someone will be able to say. It's been a few since I've had to use tune ecu.
Sent from my SM-G930V using Tapatalk
electrons were excited to send you this!
tiny tiger is offline
post #13 of 20 (permalink) Old 04-21-2017, 11:07 AM Thread Starter
Tune ECU does indeed read the O2 sensor, but I'm not sure what the figures shown actually represent. They seem to fluctuate with the bike at idle. Here's a few examples taken within seconds of each other:
0.460v 0.4
0.460v 5.9
0.260v 6.7
0.000v 9.0
0.210v 9.0
0.005v 7.5
Any ideas ??
And...........I put the old Triumph OEM map (10172) back on the bike today and let it idle. The exhaust fumes smell like they should do ?? Very strange ??
Safe riding.
Regards,
Graeme.
post #14 of 20 (permalink) Old 04-21-2017, 11:48 AM
tiny tiger's Avatar
0.460v 0.4
0.460v 5.9
0.260v 6.7
0.000v 9.0
0.210v 9.0
0.005v 7.5
Any ideas ??
I think the service manual has values for the correct readings. When I get home I can look them up.
post #15 of 20 (permalink) Old 04-21-2017, 12:25 PM Thread Starter
Thanks mate
tiny tiger likes this.
Safe riding.
Regards,
Graeme.
post #16 of 20 (permalink) Old 04-21-2017, 08:38 PM
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
They're supposed to bounce around as it constantly goes above and below the ideal air/fuel ratio but 0 volts?
http://www.ngkntk.co.uk/index.php/te...ambda-sensors/
Steve Ford is offline
post #17 of 20 (permalink) Old 04-22-2017, 05:07 AM Thread Starter
Thanks for that Steve
Hmmm, not sure about the 0 volts thing myself ?? Wonder if it's the ECU doing one of its mysterious adaptions ??
Safe riding.
Regards,
Graeme.
post #18 of 20 (permalink) Old 04-22-2017, 05:46 AM
Steve Ford's Avatar
I don't know but my 06 Tiger showed up with an air filter full of red sandy dirt from Florida and was burning through Mobil 1 at an alarming rate. The gas mileage was also mid 30s but a new filter cured that.
I switched over to semi synthetic but haven't put enough miles on to know if that will cure the oil consumption. I have to start riding that bike more and will report back.
From what you've said it sounds like you want new piston rings in the old girl and valve guide seals.
post #19 of 20 (permalink) Old 04-22-2017, 06:15 AM
Main Motorcycle: Tiger Sport
Paul49's Avatar
Other Motorcycle: Tiger 800 XRx
Extra Motorcycle: Ariel Huntmaster
Hi All,
I've been getting poor MPG lately from my 2006 955i and I've had a rich fuel / oil smell from the exhaust for years. The bike uses oil as well.
I got round to doing a compression test today, on what is a cheap and cheerful tester that I don't expect to be 100% accurate. The results were quite similar for both a cold and hot engine test:
For pistons 1 - 2- 3.
Cold engine: 105 - 110 - 100 (pretty poor IMO)
Cold engine with engine oil added to cylinders: 140 - 140 - 140.
Hot engine: 110 - 110 - 110.
Hot engine with engine oil added to cylinders: 140 - 140 - 140.
Looking at a good few videos online for Triumph engine compression tests, they are all above 150psi on a cold engine, so I guess my piston rings are worn. The increase in PSI with the addition of engine oil to the cylinders pretty much backs that up.
This all sounds like a very rich fuel mixture washing the oil off the bores, wearing out both the bores & pistons/rings.
When were the injectors last set up/balanced?
Those 955i's were brilliant on fuel, I had a ST955i, avg 56mpg ridden hard two up with full luggage. Ok we have man sized gallons & the ST's are a tad more aerodynamic but you should still get around 45.
Paul49 is offline
post #20 of 20 (permalink) Old 04-26-2017, 03:57 PM Thread Starter
Had the injectors professionally tested a few years ago, and the guy said they were perfect. Set the throttle bodies last year too.
I've just reverted back to the original map from the TOR one, as I wanted to see if that made a difference. As soon as I started the bike with the new map the exhaust fumes smelled as they should. The more miles I put on it, the more start-ups, the worse the exhaust fumes are ?? Wonder if I've got a IACV problem ??
Will report back on MPG after a few fill ups.
Safe riding.
Regards,
Graeme.
Compression test Kiwi al Classic, Vintage & Veteran 12 05-17-2015 02:10 AM
