engine light - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
post #1 of 10 (permalink) Old 03-20-2017, 12:29 PM Thread Starter
rda
Main Motorcycle: tiger 955i
engine light
everything was fine before i stored it for winter in november. Went to start it, battery was completely dead. charged battery, it starts, but now the engine light is on.
also, it turns over real slow before starting. could battery just be bad and also causing the engine light to come on.
rda is offline
post #2 of 10 (permalink) Old 03-20-2017, 12:45 PM
tiny tiger's Avatar
Do you have tune ecu and the cable? Could be a voltage issue, and a bad battery
Sent from my SM-G930V using Tapatalk
electrons were excited to send you this!
tiny tiger is online now
post #3 of 10 (permalink) Old 03-20-2017, 12:48 PM Thread Starter
rda
I have the cable, need to get tune ecu again, laptop i had it on has been reloaded. I did put a new r/r in it a couple years ago and did the mods on here for that.
rda is offline
post #4 of 10 (permalink) Old 03-20-2017, 08:08 PM Thread Starter
rda
battery tested bad so i replaced. it starts a lot better now, but the light is still on. Does it just need reset or something? OR will it go out on it's own?
rda is offline
post #5 of 10 (permalink) Old 03-20-2017, 08:22 PM
tiny tiger's Avatar
It depends on what the light is for, I would take it on a ride and see if it clears
post #6 of 10 (permalink) Old 03-21-2017, 08:53 AM
Oldmann's Avatar
It will clear in about 3 heat and cool cycles. Don't stress. I had the light come on because I turned the key on with no fuel pressure. Have fun on your bike!
Oldmann is online now
post #7 of 10 (permalink) Old 03-23-2017, 08:40 AM
Main Motorcycle: '12 T-Bird
Other Motorcycle: '08 Tiger 1050
Extra Motorcycle: Legend is sold :-(
Also, you can get an inexpensive OBDII scanner from auto parts store and read and clear the codes.
VABird is online now
post #8 of 10 (permalink) Old 03-23-2017, 08:51 AM
Main Motorcycle: 2015 Tiger 800 XCx
GearHd6's Avatar
Other Motorcycle: 1998 Daytona T595
Odds are the light came on due to low voltage. It'll go out on its own after 3 cycles like mentioned earlier.
2015 Tiger 800 XCx
1998 Daytona T595
GearHd6 is offline
post #9 of 10 (permalink) Old 03-24-2017, 08:53 AM
Oldmann's Avatar
Hard to believe you can get one for $25 USD these days. Crazy cheap.
post #10 of 10 (permalink) Old 03-27-2017, 07:06 PM Thread Starter
rda
ok, thanks guys. i have only been able to get it out once since light came on. it seems to be running fine. hopefully it goes out after 3rd ride.
rda is offline
Check engine light after tail light install JustAlloy Daytona675 Forum 3 03-30-2017 11:34 AM
Engine light and oil leak help! 2015 Tiger 800xcx chrisscram Tiger 800 - 800XC Mods & Workshop 9 09-14-2016 12:56 AM
Check Engine Light jalalski Sprint Forum 18 09-01-2016 09:00 AM
2014 Triumph Scrambler Engine Light? HoffmannPhoto Air Cooled Twins Talk 3 07-24-2016 01:08 AM
HELP: Check engine light after installing custom tail light sql-lover Cruisers - America, Speedmaster 8 02-20-2016 12:21 PM
