Tiger 955i (2004) Shifting issue - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
Old 12-03-2012, 10:50 AM   #1 (permalink)
Main Motorcycle: Tiger 955i
Other Motorcycle: BMW R75/6
Since I am a new Tiger 955 owner, it seems to me that this bike .... as lovely as it is to ride... seems very difficult to change gears. Takes more foot pressure than anything I have ever owned before. My question... Is this an issue with my bike? Or was there issues with the pre-'06 Tigers and shifting?
Thanks
BlueStrada is offline   Reply With Quote
Old 12-03-2012, 12:41 PM   #2 (permalink)
Other Motorcycle: SV650S
My 2006 Tiger has had a clunky gearbox from day one, and has always been a pig to get into neutral. If it's really bad it may be just your clutch cable needs adjustment/oiling. My 900 trophy was the same-It just seems to be the way with Triumph gearboxes.
lobout is offline   Reply With Quote
Old 12-09-2012, 07:33 AM   #3 (permalink)
Main Motorcycle: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1957 Matchless G80S
Although mine is nowhere near as nice to use as my old Commando, it's as good as most modern bikes I've ridden. I actually find that upchanges are smoother without the clutch. No problems finding neutral hot or cold, although there is a definite clonk engaging 1st from neutral..
Ian
2004 Tiger 955i
1957 Matchless G80S
iansoady is offline   Reply With Quote
Old 12-09-2012, 09:16 AM   #4 (permalink)
Main Motorcycle: 2006 Tiger '955
Hi BlueStrada,
Can you tell us how much freeplay you have on the clutch lever and how much deflection on the chain ??
These tend to be quite critical for smooth gear changes on the Tiger. Having said that, my Tiger gearbox has always been "clunky" and "notchy".
Off hand I think it's 10mm of freeplay on the clutch, and the chain should have a total deflection on 40 - 50mm.
Safe riding.
Regards,
Graeme.
Tiger-G is offline   Reply With Quote
Old 12-10-2012, 06:20 PM   #5 (permalink)
blacktiger's Avatar
The gearboxes on these are clonky/notchy but reliable. It is a case of "they're all like it sir".
You only live once, so enjoy it.
'02 Tiger955i in black.68500 miles.
'12 Tiger800XC in black. 19000 miles.
http://s396.beta.photobucket.com/use...tiger/library/
Old 12-10-2012, 11:33 PM   #6 (permalink)
Main Motorcycle: 2006 Tiger 955i
Other Motorcycle: Suzuki DR650SM
Extra Motorcycle: 1973 Norton 850
my 2006 Tiger is very notchy from 1-2 and 2-3 (higher gears are better) and I do remember reading somewhere that that is common for these bikes....have mostly gotten used to it and makes those shifts very deliberately...
m800 is offline   Reply With Quote
Old 12-11-2012, 10:59 AM   #7 (permalink)
955i Gear box shifting
Thanks all for the input... seems like most all of them are a bit similar to mine ... Cable is well lubed, adjustments are pretty much right on.. So I can live iwth it just fine...
Sure might be helpful to have a clutch lever with more leverage / adjustment. It's definitely a very basic lever design.
Thx again...
BlueStrada
Old 12-11-2012, 02:08 PM   #8 (permalink)
blacktiger's Avatar
Thx again...
BlueStrada
The only thing you can do there is fit the clutch lifter arm from a 2006 model. It has a longer arm (the bit that sticks out the top of the clutch housing) than the earlier models. Makes the feel at the lever a bit lighter. It doesn't, however, alter the notchy gear change. We're stuck with that I'm afraid.
Old 12-12-2012, 09:05 AM   #9 (permalink)
Thanks Grame...
Those are really good points to remember...
Old 12-12-2012, 09:07 AM   #10 (permalink)
Thanks for that... I would not have thought the clutch levers were any different from year 04-06... Good tip
Shifting issue aztec777 Trophy 36 04-23-2013 11:42 AM
2004 - 955i - bearing issue? evyl00 Daytona Deliberations 3 08-16-2012 01:22 PM
2004 Triumph Tiger 955i owner Tsavo The Welcome Center 0 04-21-2012 11:50 PM
Tiger 955i 2004 oil? BIG BILL Tiger Workshop (archive) 7 08-21-2010 07:12 AM
Tiger 955i ECU issue Paul T'Bird Tiger Workshop (archive) 2 02-13-2010 11:32 AM
