Tuneecu Timeout solution - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
Old 11-24-2012, 04:16 PM   #1 (permalink)
Main Motorcycle: triumph tiger 955i
Cool Tuneecu Timeout solution
I spent hours messing around trying to get the ECU map to load onto Tuneecu programme. I kept getting timed out anything between 0 and 70 %. Made sure volts over 13, tried a different cable, reinstalling drivers, various port speeds and the final simple solution was to SWITCH OFF THE FIREWALLS, I had windows Firewall and my Anti virus had a Firewall. I switched these off temporarily and down it loaded no problem. Mine is a Tiger 955i 2004. Put the off road Tors map and it runs much better at low revs with much less surging. It remains economical with over 50 mpg on a run at reasonable speeds.
triumphclive is offline   Reply With Quote
why am I getting a timeout error tune ecu mtalent ECM and FI Tuning - Help, Tips & Tricks 4 07-31-2012 05:23 PM
Attn TuneECU users - TuneECU OEM tunes required for DataBase Tom_Hamburg ECM and FI Tuning - Help, Tips & Tricks 2 01-14-2011 09:49 AM
Search Timeout Error EnigmaOMC Site Happenings and Discussions 4 11-09-2010 10:45 AM
Gas Cap Solution? Gone Cat Hinckley Classic Triples 3 06-12-2009 12:08 PM
Is there a login session timeout? rwright Site Happenings and Discussions 1 06-14-2008 04:09 PM
