Weird electrical issue/no start - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
Old 10-07-2012, 11:41 PM   #11 (permalink)
Main Motorcycle: 2002 Triumph Tiger
Extra Motorcycle: 2000 YZ426F
Originally Posted by DEcosse View Post
That is a FAIL, not a pass.
12.75 is not a good result and means you have a phase down at minimum - you either have stator or R/R fail - do the tests per the sticky reference thread.
You say you diagnosed to the regulator and replaced it, but now appears it was more likely the stator - was the R/R plug n play, or did you do any wiring yourself to connect it up?
Plug and play, I swear I did the stator tests as instructed and it passed. I will do them AGAIN and see what happens.
I've been a motorcycle mechanic for 15 years and electrical has always been my Achilles heel, I can do all the mechanical like it's nothing but electric will stump me sometimes.
With a new RR in it I will bet now it is the stator but I will do the tests again.
Dustykat is offline   Reply With Quote
Old 10-08-2012, 02:13 AM   #12 (permalink)
Legend
DEcosse's Avatar
The first simple one for stator is isolation test - unplug the stator and measure resistance between any one of the three terminals to engine ground: this should be 'open' or infinite resistance.
If it fails and you get 'short' (zero ohms) to ground, the stator is toast. (If fails, no real need to do following test - that is already conclusive - although can't hurt any worse.)
Then leave stator disconnected and start bike: measure AC Volts between the three possible pair combinations i.e. 1-2, 2-3; 1-3. All should be the same at any given rpm
i.e. check at idle and at say 4K rpm - the numbers themselves less important, their comparative values are what are (make sure throttle is constant when you measure at the higher rpm - lock it somehow so cannot change as you measure your three different pairs)
Do you work in a bike shop in Bay Area? I can stop by one day this week if you like, take a look at it for you - drop me PM if you would like.
Old 10-09-2012, 03:39 AM   #13 (permalink)
I work at Road Rider, I'll be in the shop every day this week but the bike is at home. I will redo the tests and see what I get.
Stay Tuned!
Old 10-14-2012, 07:36 PM   #14 (permalink)
Yep, grounded stator. New part on order.
Old 10-15-2012, 02:37 PM   #15 (permalink)
Legend
DEcosse's Avatar
One of those 'good news/bad news' situations - at least you know the problem now, but bites to have to lay out the cost of new part!
Did you go OEM or after-market? I've had good success with my Ricksmotorsportelectrics stator.
Old 10-16-2012, 12:30 AM   #16 (permalink)
Yea, Ricks, also Ricks for the Regulator too. At least both parts are brand new now and I shouldnt have to worry in the future. Just have to get the cover gasket, with Mountain View closed the same as my days off thats a challenge
Old 10-16-2012, 03:52 AM   #17 (permalink)
Legend
DEcosse's Avatar
Probably lucky if they have in stock anyway - order it from MADSS.com - you get 15% off list, no sales tax and free shipping if total order >$40 and it's going to come to your door!
That should be a metal*** gasket - I've had good luck removing without damaging as long as no-one used sealant in the past.
OEM part number T1261098 (that is the part # specific to the Tiger - see note below)
*** hmm - interesting - the Daytona one is metal and 2x the price of the Tiger one (which is same as the Speed Triple).
So I suspect the Tiger one is paper ...........
Even though covers are slightly different (because the stator and rotor are different) would have though the crankcase - and therefor the gasket - would be same?
Safer to order correct part I guess
Old 10-23-2012, 02:27 AM   #18 (permalink)
Got the metal gasket and the job went very smoothly. It was due for an oil change anyway
I have a very strong 14+ coming back to the battery now so this one is a done deal. Thanks for all the help!
Old 10-24-2012, 03:39 PM   #19 (permalink)
Legend
DEcosse's Avatar
Good conclusion to the story
Moot point on oil change now (especially since you said needed anyway) but there is actually no requirement to drain the oil - you only lose maybe 1/2 cup or so when you remove the stator cover.
Interesting that Triumph spec'd different gaskets - did you order under the Daytona part number, or was the Tiger one metal after all?
Old 11-24-2012, 02:28 AM   #20 (permalink)
Sorry for not getting back to you until now, been very busy lately.
I was given the option of paper or steal gaskets by the parts guy. So I took the steel. he did not tell me if the original part number was steel or not.
I changed the oil just because it was time to do so. Might as well as I have the tool box out.
Thanks again for all your help!
2007 Speed Triple. Won't start, seems like an electrical issue ? Dieter Speed Triple Forum 10 02-23-2011 01:28 AM
Weird Electrical Problem morvegil Sprint Forum 4 12-03-2010 09:51 AM
Weird electrical issue danb Twins Technical Talk 5 05-17-2010 07:46 PM
Weird electrical problem ken226 Speed Triple Forum 4 10-13-2009 12:12 AM
Weird electrical problem? Daytona Deliberations 3 07-21-2004 07:49 AM
