(I moved the other bike's question to a new thread as not relevant to this technical item - and has its own concerns)
Originally Posted by tigridr-1
... One is the 02 Tiger that I have a 955i Datona motor in. This is the one that I had to replace the ECU on. This is the one I have been talking to you about as far as the error codes that came up when I ran the Tune ecu program....
If you have a P0413 error, then your engine most certainly does not have SAI (Secondary Air Injection) installed.
One simple fix would be to use the 10181 map- you most certainly should
not use a Tiger map with a Daytona engine - the fuel and timing maps will be completely wrong
However with Daytona map, some features - like the gas gauge on the Tiger instruments - will not work with a Daytona map.
The ideal situation is to transcribe the Daytona Fuel and Timing maps into the Tiger base map. If this is beyond your comfort level, stick with the Daytona (10181) map but recognize your fuel gauge will not work.
I have to caution - and most respectfully and well intended! - that I think you might be a bit over your head to both these projects, without fully understanding the complete ramifications of your mixing/matching motors
