Brake Switch - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
Old 07-20-2012, 06:32 PM   #1 (permalink)
Main Motorcycle: 2002 Tiger
pineygroveshop's Avatar
Other Motorcycle: Craftsman 42"
Brake Switch
My brother's '06 955 Tiger's brake light is not coming on when the brake pedal is depressed. Continuity test of the switch is good. Jumping the two pins results in the light coming on. Voltage test shows @12VDC in and 1.5VDC out when the pedal is depressed. Replace the switch or bleed the system first? Or?
Cheers,
Stephen Ford
pineygroveshop is offline   Reply With Quote
Old 07-23-2012, 11:42 AM   #2 (permalink)
Main Motorcycle: Tiger 955
Other Motorcycle: SV650S
Could be the switch is sticking-it happened fairly regularly on my Trophy 900. Try some WD40 on the switch plunger and work it up and down a few times
lobout is offline   Reply With Quote
Old 08-07-2012, 07:57 PM   #3 (permalink)
juan44's Avatar
Same issue is happening to mine. I checked the switch to apply some WD40 and it looks to be totally encapsulated by rubber, so that I cant get the WD40 in there. Was it that way with your Trophy?
Jon
Sunt Nobis Dracones Interficiendi
juan44 is offline   Reply With Quote
Old 08-07-2012, 08:12 PM   #4 (permalink)
juan44's Avatar
When I stand on my back brake I get a slight illumination, but not bright like I do with the front brake. Is there an adjustment that can be made to engage the light sooner?
Jon
Old 08-08-2012, 10:58 AM   #5 (permalink)
If the switch tests out okay it sounds like a corroded terminal somewhere else or a bad bulb. If it's coming on but not brightly it sounds like corrosion, especially if the front brake lights it up. I just got WD40 in as best I could and worked the pedal
Front Brake Switch RHS2362 T3 Sport / Touring Forum 8 05-23-2012 05:09 PM
Brake Lite Switch MASHMC The Welcome Center 2 09-05-2011 12:03 AM
front brake switch connersw Classic, Vintage & Veteran 6 02-27-2009 08:44 PM
brake switch boot abruzzi Tiger Chat 10 08-17-2008 02:44 PM
brake pressure switch dpries T3 Sport / Touring Forum 4 06-20-2006 01:07 AM
