Fuel consumption -air filter - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
Old 07-17-2012, 11:03 AM   #1 (permalink)
Hi all,
Recently serviced my 04 tiger, have noticed since then that the fuel consumption has become poor.
I fitted a k&n freeflow air filter and was wondering if this could be the problem.
If it was the air filter causing the problems would i need to re tune the bike to sort it out using a tuneboy or similar ?
Tried the 12 min tune but have had no luck.
Any suggestions ?
Thanks in advance.
bandicoot is offline   Reply With Quote
Old 07-17-2012, 11:53 AM   #2 (permalink)
Main Motorcycle: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1957 Matchless G80S
I don't know but I've never been a fan of K&N - especially when they're a pain to get at as on the Tiger. It seems to me you (I) are likely to over- or under-oil them or at best have an uneven coating.
I much prefer standard paper filters - and in our cool damp climate I don't even see the point in changing them as often as specified. Might be different if you live in the desert.
Ian
2004 Tiger 955i
1957 Matchless G80S
iansoady is offline   Reply With Quote
Old 07-17-2012, 05:58 PM   #3 (permalink)
Main Motorcycle: '06 Scrambler/'07 BonnieB
cdubya's Avatar
Other Motorcycle: '05 Yamaha WR 250
Extra Motorcycle: '05 Tiger
What all did you do to the bike to complete the servicing? Anything else that may have thrown something off? An over oiled filter will cut air intake substantially and therefore cause poor fueling. I have had great luck with the K&N filter in my '05 Girlie.
'06 Scrambler: De-AI'ed, CARK/Pods, Emgo 12" Shorty's, 145mains, 40pilots, stock needles, no shims
'07 Bonnie Blk: De-AI'ed, De-Snorked, K&N + NH Peashooters, 118mains, 40 pilots, one shim
'05 Tiger 955i: No airbox plate, Debaffled stock exhaust
cdubya is offline   Reply With Quote
Old 07-18-2012, 07:13 AM   #4 (permalink)
I just used the K&n straight out of the box.
Other service things done were :
Re gap plugs
oil
oil filter
fuel fittings (Plastic for metal)
Brake pads etc
The Norm really
Old 07-18-2012, 12:26 PM   #5 (permalink)
Main Motorcycle: Tiger 955
Other Motorcycle: SV650S
I fitted K&N to my Tiger and it's fine-didn't need to retune anything and haven't really noticed any change in consumption
lobout is offline   Reply With Quote
Old 09-13-2012, 04:35 PM   #6 (permalink)
still havent managed to resolve this fuel problem.
seems to be getting worse.
Put in £15 and got out 70 miles ???? 6 miles a day to and from work.
Is this good??
As i mentioned before, does anyone think a tune up would solve the problem?
Old 09-21-2012, 12:01 AM   #7 (permalink)
cdubya's Avatar
something certainly seems off. how does it idle? any lack of power? wondering if one of your new spark plugs is faulty. does happen from time to time. adding a new k&n out of the box should not affect your tune at all unless it came over oiled. may be worth taking your tank off again and double checking all of the vacuum hoses that hook up to the throttle bodies.
Old 09-22-2012, 09:30 PM   #8 (permalink)
15 quid is about 2 gallons-35 miles a gallon seems pretty good to me considering all you are doing is short journeys. On the highway with a hot engine I'd be expecting just over 40mpg
Old 09-23-2012, 09:26 AM   #9 (permalink)
Main Motorcycle: Tiger 955i
Belton's Avatar
Bandicoot, I run my 06 tiger with a k & n air filter and reciently re-oiled filter (1 month ago) still getting good milage per gallon.
210 on approx 18lts.
I travel 15 miles each way commuting, consisting 13 roundabouts plus 2 set of traffic lights in this journey.
Belton is offline   Reply With Quote
Old 09-27-2012, 06:04 AM   #10 (permalink)
Unhappy Fuel consumption -air filter
Hi all,
Spoke to someone in Bevans who claimed that Tigers dont like K&N air filters, it messes with the computer `Brain` and suggested that i re - fit a paper element.
cdubya,
There is no lack of power and it idles fine.
When i fitted the K&N it seemed to be pretty oily,maybe i`ll try some of the comments listed and see what happens.
fuel consumption triple595 Daytona Deliberations 5 05-10-2010 06:34 PM
Fuel consumption krothnbrg The Rocket Science Forum 61 04-16-2010 05:01 PM
Fuel Consumption? Sp00ky Twins Technical Talk 6 07-25-2009 09:16 PM
Fuel consumption Wurzel Sprint Forum 12 04-04-2006 03:24 AM
TT 600 fuel consumption Triumph SuperSports 24 06-02-2005 08:18 PM
