brake caliper - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
post #1 of 25 (permalink) Old 04-06-2012, 11:30 AM Thread Starter
Main Motorcycle: Tiger 955i
Belton's Avatar
brake caliper
serviced the front brakes again today as the MOT test told me they were binding slightly.
sound a small piece of casting missing from thecaliper - dust seal area
rebuilt
it is not leaking and brakes are fine. but do you think I should replace the caliper. Tiger 955i 2006 model
Belton is online now
post #2 of 25 (permalink) Old 04-07-2012, 05:38 AM
Main Motorcycle: 2006 Tiger '955
Dave,
Haven't seen that before, any idea's on how it happened - knocked or casting defect ??
It looks far enough away from the dust seal for it not to be a problem, but for piece of mind it might be a good idea to get a new / second hand caliper.
Safe riding.
Regards,
Graeme.
Tiger-G is offline
post #3 of 25 (permalink) Old 04-07-2012, 05:53 AM
How did you rebuild the brake caliper Belton?
DeanRider is offline
post #4 of 25 (permalink) Old 04-07-2012, 11:51 AM Thread Starter
Belton's Avatar
I stripped them down, cleaned the pistons with metal polish, used muc off brake cleaner, cleaned pins, shims. removed the slider.
removed seals, cleaned behind them.
then rebuilt it.
here is a photo of the brake pads
I have replaced the pads too
post #5 of 25 (permalink) Old 04-07-2012, 06:24 PM
Main Motorcycle: tiger 1050
I wouldn't bother replacing that caliper. Looks like it's had that damage/defect for some considerable time. If it's not affected your brake performance up to now why bother ? Especially after such a professional looking repair.
In fact thinking further about this, my only concern would be the repaired bit of metal coming away and fouling/affecting your braking. You could now be between a rock and a hard place with no other alternative than to replace ??
Dave, ignore last paragraph. On first glance I thought you had repaired the caliper with some chemical metal type stuff. Hence my concern about it breaking away. I can see now you haven't done that. So back to my first thoughts - why bother replacing ?
JJ
johnjo is offline
post #6 of 25 (permalink) Old 04-08-2012, 07:03 AM Thread Starter
Belton's Avatar
cheers Johnjo, it looks like a casting fault
I have been offened another pait of calipers off another triumph, not far from you Johnjo. ]
not sure what model there are from, just checking the fixing hole centers.
took the bike out this morning, done some emergency stops all is fine at the moment but in time I will change the caliper - piece of mind.
post #7 of 25 (permalink) Old 04-08-2012, 07:17 AM
Originally Posted by johnjo View Post
Dave, ignore last paragraph. On first glance I thought you had repaired the caliper with some chemical metal type stuff. JJ
+1 Indeed, I thought you had done some fancy repair on it, hence my question.
post #8 of 25 (permalink) Old 04-08-2012, 11:40 AM Thread Starter
Belton's Avatar
sorry guys, re-assembled all the bits I cleaned not repaired.
post #9 of 25 (permalink) Old 04-08-2012, 09:00 PM
Main Motorcycle: Tiger Explorer
lobout's Avatar
Other Motorcycle: Tiger 955i
Extra Motorcycle: Wifes Honda 300
As long as damage is in front of the seal and the seal channel isn't damaged it shouldn't make any difference
lobout is offline
post #10 of 25 (permalink) Old 04-09-2012, 05:49 AM Thread Starter
Belton's Avatar
yep you are correct, channel if fine,
Brake caliper sameer9 Speed Triple Forum 7 06-05-2009 10:57 AM
brake caliper dumbremindr Air Cooled Twins Technical Talk 7 04-30-2008 01:37 AM
Brake Caliper HKTon-Up Club Cafe' 22 02-01-2006 07:57 AM
brake caliper triumphtimes Sprint Forum 3 02-08-2005 08:30 PM
