I've noticed tread wear on the left side of the rear tire wearing more than the right. Although the bike tracks correctly. It may be an old issue from bad alignment from a long time ago.
After I adjusted the chain, I measured from tire to swing arm. Now I'm thinking I should measure to the rim.
I stopped by the shop today to find out if the measurement from swingarm to rim is the same on both sides. The guys are not sure so they are going to check with Triumph. Will post back when I have the good word.
Once I know I have the alignment within tolerance, I'll polish the damaged area and set a new scale for future adjustments.
[ This message was edited by: whoa on 2005-04-20 16:41 ]
05 Thruxton
