» Log in
User Name Not a member yet?
Register Now!
Old 6 Days Ago
Favorite Bike: Triumph America
Changing gear increasingly troublesome
I bought a 2003 Triumph Tiger 955i in February. Since then it has become increasingly troublesome to change gear. The gear quite often gets stuck beteween positions. I can press the gear down endlessly without effect. It just doesnŽt change into the next gear without accelaration of motorpower. It is motly so when I stop the bike at for example red light. Any idea what this is about? I bought it from Metropolis Motorcycles in London and the guarantee runs out by the end of this month. Should I bring the bike in?
Illustrator and designer: www.espenlauritzen.com
Old 6 Days Ago
Favorite Bike: Triumph Tiger 955
Do you have too much slack in the clutch cable?
Brooks
Old 6 Days Ago
Slack?
Dunno. I am new to bikes. How do I find out?
Old 6 Days Ago
Skidpan's Avatar
Chain tension affects the gear changing on mine. The gear change loses it's smoothness, and tensioning the chain brings it back.
Old 6 Days Ago
To check if you have too much slack in your clutch lever -
You should have a few mm of freeplay (don't know what Triumph recommend), where the clutch is just free to move with no tension in the cable what so ever.
If you have too much slack on the lever, slacken the big locking nut off, screw the smaller nut out until you hav e a few mm freeplay, then retighten the locking nut. Go for a ride and check if it's any better.
Don't know about anyone else but I feel as if the clutch lever is a poor design on the Tiger - too much of a stretch.
If you bought the bike second hand and the previous owner had little hands, he / she may have adjusted the lever too far in making gear changing difficult.
Let us know how you got on.
Safe riding.
Regards,
Graeme.
Old 6 Days Ago
Cheers. IŽll try.
Old 6 Days Ago
hawkster's Avatar
Favorite Bike: Triumph Tiger ABS
Other Motorcycle: Ducati Monster
Extra Motorcycle: Honda 450X
It would be a good idea also to check your gear changing linkage to make sure it's not loose and adjusted properly. My Sprint would sometimes loosen every couple of years. A little locktite helped.
Old 5 Days Ago
There's no linkage on the Tiger. The lever is attached directly to the splined shaft.
I agree with Graeme, the clutch lever set up on the Tiger is a bit cheap and poorly thought out.
The gearbox on Tigers tend to be a bit notchy, with a tendency to baulk. As everybody mentions, you need to have the clutch lever adjusted correctly, with the final drive chain the loose side of manafacturers specification. Most people reckon on at least 60mm.
Owners say the gearboxes improve with mileage. This might be so, or perhaps we get used to them and change our riding style to suit?
Old 4 Days Ago
What kind of shape is the engine oil in and is it the proper type and weight?. Has it been changed lately??
Old 4 Days Ago
TucsonBill's Avatar
Favorite Bike: Maggie, my 1999 yellow Ti
Other Motorcycle: 1989 Honda NX650 (Dominat
Extra Motorcycle: 1968 Honda CT90
While it's true there's no linkage, check the lever for tightness. The steel shaft can chew up the aluminum lever so there's a bunch of play. I actually fabbed a new steel lever from a Honda lever that I made the length I preferred. The shaft size is pretty common, so before you shell out too many bucks, pounds, euros, or drachma, for something that says "Triumph" check with your neighborhood breaker for something made of steel if you want to go the replacement route. The steel lever will also withstand those times when the Tiger wants to lay down to rest.....
William Fee
Iron Butt #26777
Tucson, Arizona
Gears / Gear Changing? GrahamG Sprint Forum 12 05-01-2007 11:59 AM
Gear changing problems JLuck Sprint Forum 4 04-05-2007 05:51 PM
Changing gear box oil ggale Modifications & Workshop Talk 3 12-06-2005 01:32 PM
Clutchless Gear Changing Tbird95 Hinckley Classic Triples 5 10-21-2005 02:05 AM
changing gear side panda Classic, Vintage & Veteran 4 06-14-2004 06:41 PM
