» Log in
User Name Not a member yet?
Register Now!
Old 1 Week Ago
Favorite Bike: 955i Tiger
Headlight adjustment
Up until today I possessed a reasonable amount of self-esteem as a mechanic, until I went to adjust my headlights.
I had fitted some more powerful halogens and I also fitted the relay to put both beams on (a couple of years ago). I do very little night riding but the other night I realised the beam(s) were a bit low and appeared really odd when swinging around bends. On checking them I discovered the headlights were miles out of lateral alignment, so bad that the beams crossed; not noticeable when riding in a straight line but weird when cranked over.
Its a real hassle taking off the fairing, fiddling with those little nuts (made myself a little twizzling tool), sitting on it to compress the suspension, assembling everything only to find it’s not right when back on the open road.
I’ve never had lights that have been such a hassle to adjust. I love the way Haynes award just one “difficulty spanner” for headlight adjustment. And, haven’t Haynes also got it wrong with there “top screw for vertical adjustment, bottom screw for lateral adjustment”?
Now that nighttime has arrived I’m going out to give ‘em another go. Can’t believe I’m only doing the headlight adjustment.
There was a time when a headlight only needed a good thump. Any handy hints will, once again be very gratefully received.
Old 1 Week Ago
miker's Avatar
Moderator
Favorite Bike: 2006 Tiger
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Send a message via AIM to miker
Be careful with higher wattage halogens. If they're normal halogens and putting out 110watts or so, they could be melting the innards of the headlight mounting, or the plastic three pin connector, hence the "out of adjustment"
At least, that's what happened to my Speed Triple, resulting in me having to put new connectors in, as well as lower wattage halogens.
Of course if you have the higher output lower wattage Halogens, ingnore everything I said.....
Mick
My Album
Old 1 Week Ago
Favorite Bike: Black 2002 Tiger
Tiger lights are a pain in the ass. A remote method of vertical adjustment would be lovely since every change in load requires an adjustment. Seems as if the designer lived in an area lit by streetlights and never left it. Poor lad never saw the stars.
Old 1 Week Ago
Tonto's Avatar
Favorite Bike: Black 03 Tiger 995i
Tone, your right Haynes got the adjustment knobs mixed up and when you figure that out it's still a real pain, I still haven't got mine adjusted as well as I would like them to be and I've had the front off at least four times.
Old 1 Week Ago
Headlights
Jeez, I didn't know they were such a pain. I have been needing to do mine for some time. I was wondering if the guy before me didn't adjust them correctly or what, but I have been lighting the sky alot with my low beams, but now I realize that I put a givi trunk on and added a bit of weight in the rear, that's probably why. Any mods to correct the headlight adjustment knobs?
Old 1 Week Ago
blacktiger's Avatar
Wrong.
When you load the bike you should be adjusting the rear spring pre-load to restore the ride height to what it was before you loaded it. That's why there's a remote pre-load adjuster on the shock. Doh!
H
'02 Tiger955i in black.
Old 1 Week Ago
You are absolutely correct Blacktiger. Still.........it would be nice to be able to adjust remotely. Sometimes the change in load isn't for a long enough period or the change in road is for only a short time. Actually, there is no remote adjuster on my shock.
Old 6 Days Ago
katoomon's Avatar
Favorite Bike: YES
Other Motorcycle: 04 KTM 625SXC
I have been fiddling with my headlight adjustments lately, they were crossed as well. I am using a 10mm ratcheting box wrench, a Park tools bicycle tool. It is very fast and convenient; well, convenient after the screen and nose are off... what a pain. When covering one (USA, both are on) to adjust the other, it is apparent that the patterns are very different and I may resort to unplugging one, getting it right then unplugging the other. As it is now, there is a dark hole right in front of me.
Low beam performance and reach really sucks, the narrower high beam is a little better. Bike had PIAA lights on it when purchased used, they help a bunch.
Old 4 Days Ago
TucsonBill's Avatar
Favorite Bike: Maggie, my 1999 yellow Ti
Other Motorcycle: 1989 Honda NX650 (Dominat
Extra Motorcycle: 1968 Honda CT90
Don't unplug the lights, just throw a towel over one, then the other. You can go back and forth more quickly, which you will need to do! My low beam is OK, my high beam is OK, but when I turn on the PIAA 910 HID conversions, life's really GOOD!
William Fee
Iron Butt #26777
Tucson, Arizona
Headlight adjustment.... KevyKev Sprint Forum 13 11-13-2007 03:41 PM
Headlight Adjustment English_Spanner Twins Technical Talk 10 10-08-2006 12:22 PM
Headlight adjustment dickieshep Sprint Forum 2 05-12-2006 08:48 AM
Headlight adjustment Swiss-Tony Speed Triple Forum 0 05-09-2006 12:34 AM
Headlight adjustment? Olathe-ST Sprint Forum 5 05-13-2004 02:44 PM
