BikeBandit
Old 04-29-2008   #1 (permalink)
FantomasRR3's Avatar
Question Clutch disk
Hi,
I am a new Triumph owner since March. I have a White Tiger 1050 2008 with 3500 km. I have a problem with with my clutch disk and I'll try to be as clear as I can to ask for your advise/help... :-)
The coupling was not smooth since 500 km... the shifts were herd and the gearbox made some clutching sounds. I went to the dealer who tells me the clutch disk is burnt... Ok seen the symptoms I believe him.
The problem is that he says that this does not fall under the warranty policy of Triumph... but the bike never really reacted well, even after the first 700 miles checkup by the dealer. What should I do ? I didn't do anything wrong and the clutch disk is burnt after only 3500 km... not normal... should be a warranty issue... what do you think ?
Thanks
Tiger 1050 '08 White
Triumph sport exhaust
TG Warning System
FantomasRR3 is offline   Reply With Quote
Old 04-30-2008   #2 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Fantomas, I'd go to another dealer.
Your clutch is a wet clutch, so burning the plates would be really hard in just 3500 km, unless you spend all your time drag racing.
My bet is that the clutch cable isn't adjusted properly, which will cause rough and noisy shifting. That coupled with the fact that these bikes are notorious for notchy shifts when they are new.
http://www.cyclefish.com/tech_tips/l...utch_cable.asp is not a bad place to get an idea on how to adjust your cable, but better still, get a shop manual to show you exactly how to do it. It's really the first thing to check with hard shifting.
Mick
My Album
miker is offline   Reply With Quote
Old 04-30-2008   #3 (permalink)
thanx
Once again, thanx for the detailed answer Miker. I'll check with the dealer again to get his final position on that but I also think he didn't set the cable the right way when the bike came out of the factory... I hope he wont say its me or something else to avoid the warranty....
Thanx
TG Warning System
Old 04-30-2008   #4 (permalink)
Thumbs up Epilogue
The dealer opened the gearbox this morning... verdict: no burnt clutch disk and the warranty runs because its a known problem of "sticking" clutch disk. Apparently I'm the first one in Belgium to have this kinda problem, together with two others in Germany. They will replace it without any extra cost from my side ;-)
The point is that if this happens to you, DO NOT BELIEVE your dealer that says its another problem (tight cable, etc..). Mine (dealer) excused himself not believing me when I said I didn't touch anything.
Feel free to ask for more details if you are unfortunate as I was ;-)
Fantomas
TG Warning System
Old 05-01-2008   #5 (permalink)
blacktiger's Avatar
Hope it wasn't Christian Mourin in Ath giving you the run around. I know Christian and always thought he was a straight geeza.
H
'02 Tiger955i in black.
Old 05-01-2008   #6 (permalink)
Wink reply
No my Dealer is in Charleroi (Bailleux). Everything Ok now he believes me :-) Until now nothing ELSE to complain from him ! He is cheap compared to Brussels dealers and I had a really good price for the bike.
TG Warning System
Warped disk and hub? PfM Twins Technical Talk 3 06-11-2007 01:19 PM
'72 OIF BSA Disk Conversion kcfoster Classic, Vintage & Veteran 7 03-25-2007 01:11 AM
New brake disk - Again! Lobo Twins Technical Talk 9 09-19-2006 08:59 AM
Brake Disk Bolts Dickie2679 Twins Talk 2 08-26-2006 05:34 PM
tax disk holder russd01 Twins Talk 10 05-31-2006 10:40 PM
