Old 04-27-2008   #1 (permalink)
Mk7 Scottoiler.
Ive just bought a Mk 7 Scottoiler complete with the Triumph vacuum pipe and t piece.
Can anyone tell me where about is the best place to fit the main body of the oiler.??
inchcape01 is offline   Reply With Quote
Old 04-27-2008   #2 (permalink)
Favorite Bike: Tiger 1050
Other Motorcycle: Fazer 600
You should be able to get some ideas in the album section:
http://www.triumphrat.net/photogalle.../Chain-Oilers/
Personally I used to have the scottoiler mounted to the frame behind the left hand sidepanel (think one of the pictures in the album shows this - not a scottoiler, white bottle, but same location). I would however not recommend this unless you can't find space anywhere else - having to take the sidepanel off every time the oiler needs filled is a p.i.t.a. and also caused me to crack screwholes after tightening panel screws up too much .....
TorqueyT
TorqueyT is offline   Reply With Quote
Old 05-02-2008   #3 (permalink)
mine's fitted to the rear and right of the battery, easy filling as the berather hole is at the top end and as it's vertical you get a good reservoir full before re-filling.
I think there are Triumph fitting photos on the scottoiler website, maybe not for the reservoir though.
If you've the touring reservoir, behind the number plate's a popular spot.
FifeTiger is offline   Reply With Quote
Old 05-02-2008   #4 (permalink)
Favorite Bike: Tiger 05
Silverstripes's Avatar
Mine is fittted by the side of the Battery, behings the left side panel. I use the breather tube to refill and this is just looped under the seat.
Silverstripes
Silverstripes is offline   Reply With Quote
Scottoiler..... casperghst42 Sprint Forum 2 05-23-2006 09:30 AM
Scottoiler llewpants Tiger Mods & Bolt-Ons 21 02-22-2006 02:01 AM
Where to put a Scottoiler? Bazzer Twins Talk 10 01-24-2006 01:50 PM
oil in a scottoiler?? jaben Hinckley Classic Triples 9 10-31-2005 01:36 PM
Scottoiler RMV on 955 RS - where?? mathbeak Modifications & Workshop Talk 0 09-02-2005 07:29 PM
