» Log in
User Name Not a member yet?
Register Now!
Old 4 Weeks Ago
Head gasket blowing bubbles of oil !!
My 07 plate 955i tiger, (last of the 06 models) has only done 1900 miles and has started bubbling oil out of the front right hand corner of the head gasket, Triumph dealer fitted a new gasket but this did not work. Dealer now scratching his head.
I'd have thought that Triumph would have had the 955i engine well sorted by now.
Anyone got any ideas.
Cheers.
Old 4 Weeks Ago
Tbirdnz's Avatar
Favorite Bike: '98 Triumph Thunderbird
Other Motorcycle: '05 Honda CB1300
Extra Motorcycle: '62 AJS 650 Twin
Looks like you got a one-off. Head could be slightly warped or it wasn't torqued down correctly. I'd put it back to the dealer for a further check of the head and if that's ok then try another new gasket.
The mechanic should have also used new O-rings on the cylinder dowels before installing the new gasket, this will ensure proper alignment of the head gasket.
Ride on !
Old 4 Weeks Ago
miker's Avatar
Moderator
Favorite Bike: 2006 Tiger
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Send a message via AIM to miker
Just a thought, are you certain it's a head gasket, and not the rubber valve cover gasket?
If it is the head gasket, John is perhaps correct. Has it ever been overheated?
Mick
My Album
Old 4 Weeks Ago
Tigeer blowing bubbles
Thanks for the reply guys.
I will mention the rubber thingy to the Dealer tomorrow. I rang them today but the guy i need to speak was not in. They did say though that they had sent the head to an engineering firm who said it was perfectly flat. So I don't know where I am at the moment.
It has never been over heated, I'm a fine weather biker who rides for pleasure only. It was carefully run in and is not thrashed.
Will update when I get an answer.
Cheers.
Old 3 Weeks Ago
Update
Triumph dealer is trying a second head gasket. If that does not work then the bike is going back to the factory where they are better equipped to fix the problem.
Old 3 Weeks Ago
Cheers.
Therein lies the problem.
Old 1 Week Ago
Sorted
Righty ho then.
seems that the head was not torqued down enough.
service chap said that the setting had been updated but this dealer was unaware of it.
all seems o.k. now.
Cheers.
Old 4 Days Ago
Hey Tigerrider,
i have just booked my 05 Tiger into my dealer for,what seems to be, exactly the same issue.
Oil misting out of the front RHS as your sat on the bike.
They are replacing the Gasket,Bolts,Oil and Filtet etc and believe it will do the trick. Worryingly, mine is 6 months out of Warrenty and i have only had it 12 months.
Bought it when it had 811 miles on it, now has just short 5k - i bought this bike because of its reliability - am now thinking about chucking it in for a 1050. Will see how it goes. Dealer have been brilliant so far.
HELP! oil leak from osf corner of head gasket,only 1300 miles on the clock slade Twins Technical Talk 1 05-08-2007 04:47 PM
HELP! oil leak from osf corner of head gasket,only 1300 miles on the clock slade Twins Technical Talk 7 05-08-2007 03:24 PM
Oil Leak head gasket? and looking at Dennis's T100 at dealer jwpT100 Triumph Twins HangOut 3 11-17-2005 07:39 PM
Head Gasket?? triumphrdr Speed Triple Forum 14 11-12-2005 07:41 PM
Head gasket oil leak - comments........ shards Speed Triple Forum 5 09-12-2004 01:06 AM
