Old 03-02-2005   #1 (permalink)
I wonder if anyone could shed some light on a little problem I'm having.
When I set my scotoiler to prime the oil comes free flowing out no problem. However, when I set the oiler to a more reasonable rate no oil comes out at all.
I have tried setting it to MAX (Just less than prime) but still no oil.
It has been working before after the dealer fitted it for me, but just seems to have stopped working
Any help much appreciated :???:
[ This message was edited by: Freddy on 2005-03-02 03:19 ]
Ian (Freddy) Thomas
MY TRIUMPHRAT PHOTO ALBUM
Visit SirenHost for WebHosting
Freddy is offline   Reply With Quote
Old 03-02-2005   #2 (permalink)
robbie's Avatar
pull the little black pipe of the top and see if the bike's idle speed changes. stick a bit of you on the end and feel if there is any suction as you rev the bike up.
if you have suction then it may be a split diapham in the oiler.
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
My Photos
robbie is offline   Reply With Quote
Old 03-02-2005   #3 (permalink)
Cool, off to shove bits of me into the vacuum :wink:
Will report back
Ian (Freddy) Thomas
Old 03-02-2005   #4 (permalink)
Favorite Bike: Tigger of course (2004)
bigD's Avatar
Another possible problem is that the vacuum pipe has got squished, finding that can be a bit more of a hassle cos it involves a bit of dismantling to see if the pipe is free under the tank if nothing is obvious further back.
D
Big D
If you can't be kind, at least have the decency to be vague.
bigD is offline   Reply With Quote
Old 03-02-2005   #5 (permalink)
I had a similar problem and it was the vacuum pipe had pulled out of the T peice at the take off point. Some idiot (me) had pulled it out while cleaning the bike. Had to pull the tank off and a little silastic applied carefully so not to block the tube and to glue it in place and a judiciously applied cable tie fixed this permanently.
Timtiger is offline   Reply With Quote
Old 03-03-2005   #6 (permalink)
Hmmmmm taking tank off sounds tricky to me (Clueless spanner monkey)
Is it difficult an how do I do it?
Ian (Freddy) Thomas
Old 03-03-2005   #7 (permalink)
Ian (Freddy) Thomas
Old 03-03-2005   #8 (permalink)
blacktiger's Avatar
If the diaphram is split you'll get the oil sucked out of the reservoir into the engine and lots of bubbles in the reservoir and the engine will smoke a lot.
Mine did this after a tumble (broken collar bone etc.) I thought the engine was phuqed. What a relief to discover the Scottoiler was to blame.
H
'02 Tiger955i in black.
Old 03-03-2005   #9 (permalink)
blacktiger's Avatar
H
Old 03-04-2005   #10 (permalink)
Well the scotoiler isnt bubbling and the exhaust isn't smoking so thats okay then
Cant get a peice of me on the end of the pipe. Scared to pull the vacuum pipe out of the RMV in case I break it and I cant see how you get the tank off to trace the vacuum pipe.
Need to get the tank off really. (Do I??????)
Ian (Freddy) Thomas
Scotoiler littonlad Sprint Forum 6 04-23-2006 02:13 AM
scotoiler/ tail tidy karl Sprint Forum 11 02-02-2006 01:53 PM
Scotoiler Sprint Forum 3 09-08-2004 09:26 AM
Scotoiler weres yours Mutley Tiger Chat 7 04-07-2004 11:52 AM
Scotoiler Mutley Tiger Chat 4 02-21-2004 08:42 AM
