Motorcycle.com
Old 04-04-2008   #1 (permalink)
03 Cutting Out
Hi all,
Quick query regarding some random cutting out on my 03 955i. I've never had this kind of problem with it before, but every so often I'll be riding when all of a sudden I completely lose all drive for about a second whilst the MIL and the Low Fuel lamp both light together. About a second after I regain drive, the two lamps extinguish again.
I'm suspecting it's a dodgy electrical connection somewhere because a couple of times it has happened whilst riding over a big bump, but I'm not quite sure where to start looking!
I was wondering if anybody else had experienced this before? My first suspicion was the sidestand cutout switch, but when I experimented this simply cuts the ignition without displaying any lamps which seems to eliminate it.
Any help much appreciated
Cheers,
Tim.
tcowjww is offline   Reply With Quote
Old 04-04-2008   #2 (permalink)
robbie's Avatar
sounds like a loose connection.
have you done anything recently?
start with the battery and the connectors under the seat
in 03 there was a recall on the ignition switch wireing so have a look around that area, the bolts can work loose.
mine is an 03 and the side stand switch has been playing up but not as you say
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
My Photos
robbie is offline   Reply With Quote
Old 04-04-2008   #3 (permalink)
Hi Robbie, thanks for your swift reply.
I've not made any changes recently. In fact, it's the first year in a long time that I've barely ridden through the winter months. Hope I'm not becoming "fair weather" <gasp> ;-)
My only (and probably quite significant) crime was putting the bike away wet on several occasions and letting it fester (I paid the price by having to completely strip and overhaul the brakes as punisment!). I imagine this is unlikely to have done any exposed electrical connections much good either.
I'll give it a good going over tonight and disconnect/reconnect/tighten as many things as possible, with lashings of WD40 and see how it performs over the weekend
Thanks again,
Tim.
Old 04-10-2008   #4 (permalink)
Thanks again, Robbie - 100% correct!
Never been caught out by loose battery terminals before because the bike doesn't normally stay in one piece for long enough for them to work loose
But sure enough, the negative terminal was loose.
Have duly tightened and all is back to normal!
Cheers,
T.
Old 04-10-2008   #5 (permalink)
Favorite Bike: 2003 Tiger 955i
Other Motorcycle: 1953 AJS 18S
Extra Motorcycle: 1972 BSA Fleetstar
So's mine and so's mine - and last night in particular when I was in a hurry to meet some chums for a ride. The switch plunger wasn't popping out at all when the stand was up! Lashings of WD40 inside the rubber boot and working it in and out sorted it.
ChazzyB is offline   Reply With Quote
Old 04-10-2008   #6 (permalink)
robbie's Avatar
Cheers,
T.
Jeee glad to help
the tiger for some reason likes to loose the battery.
I havent had a problem but they never seam to be tight when removing the battery.
I thought it was all the extra ring terminals on mine (from all the gadgets) but I know several people that have been caught out.
it may be somthing to do with the plastic box allowing the battery to move slightly. always the negative side to!
TIGER 955i 2003
My Photos
Old 04-10-2008   #7 (permalink)
robbie's Avatar
now it is freed up squirt some form of grease in there
the WD40 will not last ( don't ask)
TIGER 955i 2003
My Photos
Old 04-28-2008   #8 (permalink)
Favorite Bike: 2001 speed triple
Hi,I have just had the same on my 2001 speed triple.
Mine wasn't completely loose, but I could easily twist the positive lead round with my hand.
The battery really should be bolted down solid, rather than floating under a plastic bracket,I think!
DEAN C. is offline   Reply With Quote
Old 05-02-2008   #9 (permalink)
doctordee's Avatar
I had the same problem with my 2004 tiger, but it wasn't a loose connection, it was the battery moving in the casing and the negative or positive connector touching the frame. I bit of cardboard wedged down the back of the battery sorted that problem.
Power is interactional: To understand it we must comprehend the behaviour of the powerless as well as the powerful.
doctordee is offline   Reply With Quote
cutting out greasygraeme Speed Triple Forum 6 4 Weeks Ago 08:48 AM
t300 cutting out philthymur T3 Sport / Touring Forum 11 04-03-2008 04:02 AM
Cutting Out brianre Tiger Workshop 7 08-25-2007 09:37 AM
engine cutting out funderbird Hinckley Classic Triples 14 10-26-2006 11:11 AM
Cutting out in the rain ? Normandy Twins Talk 8 08-22-2006 06:38 PM
