AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBanditMotorcycle.com
Old 04-03-2008   #1 (permalink)
Newbie
Favorite Bike: Tiger 955i
MOG69's Avatar
Other Motorcycle: Ducati
Unhappy Tank help
Hi all, I need some help with my 2001 Tiger.
I've just fitted a Scottoiler and found that I have a spare small black pipe left over! Durrrrrrrrrrrrrrrrrrrrrrrrrrr!!!!!!!!!!!!!!!!
Would any of you have a diagram or schematic of the petrol tank, or connections to the petrol tank? The Haynes book of jokes does not show a Tiger's tank. Before I take it all apart again, I'd like to know what connections there are to the tank or airbox housing.The bike runs fine and I'm thinking it might be an over flow pipe etc.
Thanks
MOG
MOG69 is offline   Reply With Quote
Old 04-03-2008   #2 (permalink)
robbie's Avatar
the tank has 2 small bore pipes on the LHS to drain the filler cap and vent the tank.
the vent line has a rollover valve
I think the vent is closest to the bike but check by poring some water over the closed filler cap.
the 2001 has a small bore pipe from the RHS of the airbox to the pressure regulator on the tank. this is missed on later bikes
large bore pipe for breather on the LHS of airbox
the other pipes are fuel and have the push on connectors
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
My Photos
robbie is offline   Reply With Quote
Old 04-03-2008   #3 (permalink)
Newbie
MOG69's Avatar
Robbie,
Thanks ever so much for the info, I'll go down the garage now and see what's what. Although by the sounds of it I think its going to be the vent pipe for the tank.
Thanks again for your help.
M
Will Truxton Tank badge fit a Speedmaster Tank ?? singring Twins Technical Talk 2 02-14-2008 09:09 PM
Tank Bag That Snaps on to the Tank Cap BOX6 Speed Triple Forum 4 06-21-2007 03:33 PM
Regular fuel tank vs. reserve tank question Newbritrider Twins Technical Talk 14 03-30-2007 03:53 PM
tank rack, locking gas cap, tank bag GleaminTwin Twins Talk 6 08-03-2006 08:29 AM
Triumph tank cover has marked the tank (05S3) Smitty Speed Triple Forum 1 09-30-2005 08:57 AM
