Old 03-30-2008   #1 (permalink)
similar overheating problem
Recently my 06 tiger has been having some cooling issues.
I first noticed the smell of steaming coolant while idling at stoplights and that my fan wasn't coming on. However, the temperature gauge never went past half way. This went on for a few days and this weekend I decided to just let it idle to make sure that my fan hadn't gone bad. It idled fine for several minutes with the temp gauge well below half way until suddenly smoke started to plume out of the dash and then the fan came on.
After reading all the other posts on this issue, what is throwing me is that the temp gauge never showed overheating. Does this mean I have a bad sensor, or do I just need to check the levels and replace the rad cap.
Any ideas?
Thanks in advance!
Moonshine
moonshine is offline   Reply With Quote
Old 03-30-2008   #2 (permalink)
Favorite Bike: Tiger 1050 '08
Other Motorcycle: Tiger 955i '06
hmmm
Yout will have to find out where it leaks. It might be radiator cap, loose hose, anthing including temp sensor or even thermostat.
slayer is offline   Reply With Quote
Old 03-31-2008   #3 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
If you've been low on coolant, the temperature sensor may not have been seeing the correct temperature as it would only be intermittently submerged. Your bike should be too new to have the crossed over pipes to the expansion tank but worth a check.
You'll need to take the tank off anyway to check things out, including the real coolant level.
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 03-31-2008   #4 (permalink)
for the posts
Took the cockpit and talk off and found that the elbow connector on the return hose was broken and coolant was leaking from there. Radiator was also low. New parts on order. Will do a coolant flush and refill and hopefully that will fix it.
Moonshine
Old 04-01-2008   #5 (permalink)
pineygroveshop's Avatar
Here is a link to some helpful info: http://www.triumphrat.net/tiger-work...ighlight=flush
Cheers,
Stephen
Pack Leader
CARAT
pineygroveshop is offline   Reply With Quote
Similar Threads Re-Activated Shawn Happenings and Discussions 0 02-17-2008 04:12 PM
Similar Powerbronze Windscreen? fivehundo Daytona Deliberations 4 10-26-2007 10:42 AM
Overheating Problem/Case Cover Torque Specs amillers3 Speed Triple Forum 8 07-01-2007 05:35 PM
SIMILAR PROBLEMS FANTA Twins Technical Talk 7 06-15-2007 09:52 AM
similar to xs650 mrcheese Classic, Vintage & Veteran 8 05-21-2006 11:28 PM
