Motorcycle.comBikeBanditAdvanstarMotorcycleShows
ShopTriumph.com
Old 02-26-2005   #1 (permalink)
Picked my 01 up after some top end work. It seems to run a bit rich and when I asked was told they set the Tiger a bit rich. But not so much to be a problem so long as I punch it around every now and again. I figure I can do that.
So is anyone aware of the practice of setting the bike a tad rich? This bike had a problem before I bought it with another dealer setting it too lean resulting in valve work. So they may be concerned about this bike, rather than a 955 issue in general.
05 Thruxton
whoa is offline   Reply With Quote
Old 02-26-2005   #2 (permalink)
How many miles do you get out of a gallon?
I get about 44 miles/US gallon but I prefer to say 5,3 L/100 km. I think there is a thread about fuel consumption.
The fuel injection can not just be set to run rich without change the settings in the EFI computer. Same as download a new tune as they do if you for example change exhaust can.
A modern engine should not burn fuel so the exhaust can get black with layers of carbon inside. Feel with your finger, it should be a grey color.
Anders
doitright is offline   Reply With Quote
Old 02-27-2005   #3 (permalink)
djr
maybe its set up for the aftermarket can rather than the standard one?
David
My Photo Album
My Tiger pages
djr is offline   Reply With Quote
Old 02-28-2005   #4 (permalink)
I have not checked mpg yet but will on my next weekend trip. I was told to do the same thing to help determine whether I need 89 or 93 octane.
Right now it is a light layer of black. I'll run it back to the shop and let them have a look. Thanks for the tip.
djr, the dealer told me they set the mixture a bit rich. I'm not sure if it is because of the previous problem with this bike being run too lean, or if that is a common practice for this engine.
05 Thruxton
Old 02-28-2005   #5 (permalink)
After I fitted an A/M exhaust the mixture had to be adjusted, it was runnig lean.
The bike runs smooth in all gears at all speeds.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Fuel mixture DreamWeaver Twins Talk 6 11-01-2007 10:51 AM
F/A mixture? rockinokie Twins Technical Talk 9 09-13-2007 03:01 PM
daytona 955i/speed triple 955i luggage differences? LOWEY Daytona Deliberations 0 01-01-2007 01:47 PM
mixture screws acelegend Hinckley Classic Triples 1 07-25-2006 08:30 PM
airscrew mixture Daytona Deliberations 6 05-19-2004 02:39 AM
