Motorcycle.comBikeBanditAdvanstarMotorcycleShows
ShopTriumph.com
Old 04-12-2008   #21 (permalink)
Smile
I'm also Black with reasonably shiny bits in Essex. This is maybe about the 15th Hinckley Triumph I had bought since 1994 and too be fair, the only one that has ever given me any significant problems. However, if this China sourcing thing is going to be a long running episode in the Company's history, I may also be a part of that history! There can be NO excuse for sourcing sub-standard parts into a premium product IMHO. No problem with out-sourcing - all the major manufacturers do it, in any industry. But to ignore primary quality and safety standards and then be in denial at the customer interface is a step too far (again IMHO).
I really hope that from my view-point this is end of story.
All the best
Rob
Rob Gibbons is offline   Reply With Quote
Old 04-12-2008   #22 (permalink)
blacktiger's Avatar
I've had my Tiger from new in August 2002 and I've just replaced my original discs at 48000 miles because they were worn out.
The originals have "SUNTAR" on them as a trade mark. Sounds China to me. Maybe the cast wheel don't dissipate the heat so well as the spoked wheel hubs.
Anyway, I replaced mine with floating discs from "Stealth Products" at £295 for a set of 3 discs and pads. It took them a while to get the order right but since fitting them I've been very happy with them.
H
'02 Tiger955i in black.
Old 04-13-2008   #23 (permalink)
Thumbs up
I read your note earlier and I think you have the ultimate solution there. Do you have part numbers for the Stealth discs/pads?
Cheers
Rob
Old 04-28-2008   #24 (permalink)
Thumbs up
Just a footnote - have now done a few hundred miles with the JMJ Engineering discs in all weathers and they have bedded in well with OE pads. Smooth braking and (so far) no rust. I have taken the OE discs to an engineering chum and as they are stainless iron and magnetic they can possibly be ground flat without removing more than 10 thou. Bearing in mind other comments that Sunstar OE discs have achieved significant mileages without problems, albeit it on wire-wheeled bikes, this may be a cost-effective longer term fix.
Old 04-28-2008   #25 (permalink)
blacktiger's Avatar
Cheers
Rob
Sorry for the delay in replying. It's probably no help anyway now you've gone for JMJ but Stealth don't seem to have a part number.
H
Another New Year's resolution ohiorider Twins Technical Talk 9 01-09-2008 10:40 PM
Cold Start Resolution!!! johnnyeastside Twins Talk 6 11-22-2007 12:13 PM
Coils (Dare I Say It?): A Resolution bajajoaquin T3 Sport / Touring Forum 5 10-26-2007 02:51 AM
Brake trouble, anybody else rebuilt the front brake Master cylinder uzidzit Twins Technical Talk 3 10-13-2007 12:55 AM
Brake light - front brake Trudie Classic, Vintage & Veteran 8 03-16-2005 09:19 PM
