Check fuse #3 in your fusebox under the seat, mine blew recently due to water shorting the unused heated grip connector behind the instrument panel. Lesson learned: don't spray the hose under there while distracted talking to your 5 year old.
That fuse also powers your trip meter (not the odometer, but the trip meter memory, it will reset whenever you turn the key off), the heated grips, clock and auxiliary socket.
Worth a shot, check it out. SHould be a 10A red fuse.
