Motorcycle.com
Old 03-17-2008   #1 (permalink)
Low fuel light won't go out
OK, I've had this problem a while now, maybe a year !
Initial problem was fuel gauge stopped working but light stayed on. Local mechanic rewired a connector and the guage got going again but permanently read high, low fuel light stayed on.
Dealer suggested ECU corrosion, but have been unable to check that by swapping the ECU out. Instead bought a used fuel float which is now in.
Fuel gauge now goes up and down as the bike points up and down hill, which should be good news, but still to run it low to see how accurate it's reading.
BUT
the low fuel light remains on......
Any suggestions ?
The weird thing is, every now and then it goes off and stays off for minutes at a time. Could it be as simple as a dodgy connector somewhere ?
FifeTiger is offline   Reply With Quote
Old 03-17-2008   #2 (permalink)
Favorite Bike: Tiger 1050 '08
Other Motorcycle: Tiger 955i '06
maybe corrosion, cracked wiring, etc.
slayer is offline   Reply With Quote
Old 03-18-2008   #3 (permalink)
Anywhere in particular I should look out for ?
Nowhere expensive, bikes a 2002 on 36k as it is, so a summer of fun and then ebay I think.
Old 03-18-2008   #4 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Fife, you should be able to pull the plastic side covers, seat and tank fairly easily. From there, it should be just one of the wires into the fuel pump area in the tank.
Mick
My Album
miker is offline   Reply With Quote
Old 03-18-2008   #5 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
Not quite, the fuel gauge is ion the RHS and the pump on the left....
I would have suggested changing the sender unit as I had a very similar problem on my 04 and that sorted it, but I see you've done that. The light and gauge are both driven by the sender so I would start to suspect a problem with the ECU, which converts the resistance seen at the sender into the appropriate signals for both the gauge and light.
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 03-18-2008   #6 (permalink)
that was the dealers first suggestion - the most expensive one !
Thought I'd try the sender first, if the gauge is now near enough accurate I'll live with the light staying on.
It's been on so long I dismissed the ecu theory on the basis it would manifest itself in progressively worse ways, but it hasn't.
36k service due soon, will ask them to have a fiddle then, stick the off road tune in, replace a seal that's leaking oil and then see how much money I have left.
I'd hate to spend £100 on a used ECU and find the bl**dy light still on !! :-)
Old 03-18-2008   #7 (permalink)
huh thats ironic mine never comes on lol!!! even when i know its way low
aisurffish is offline   Reply With Quote
Old 03-19-2008   #8 (permalink)
robbie's Avatar
Any suggestions ?
Bulbdectomy -- works every time
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
My Photos
robbie is offline   Reply With Quote
Old 03-19-2008   #9 (permalink)
Favorite Bike: Triumph Tiger
MAX21's Avatar
Seconded once its gone it won't bother you anymore
MAX21 is offline   Reply With Quote
Old 03-20-2008   #10 (permalink)
robbie's Avatar
Bulb is live and the ECU switches to earth.
have a look at the green- green black wire going to the ECU
if this wire is grounded the light lites
TIGER 955i 2003
My Photos
Fuel Gauge Low Fuel Light problem any ideas ? CYNCRZR Sprint Forum 4 06-09-2007 11:36 PM
o7' tiger fuel low fuel light spezz1 Tiger Chat 5 06-04-2007 09:54 PM
Fuel Gauge OK, Low-Fuel light intermittent andy-D Tiger Chat 3 11-16-2006 04:46 PM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 08:18 AM
Fuel Guage & Low Fuel Light Fatbob Tiger Chat 4 08-09-2004 04:33 PM
