Old 03-09-2008   #1 (permalink)
check engine light
got a 2004 tiger and i have a check engine light on. i think it came on because i started it and let it run in a confined area to charge the battery for 10 mins or so. the carbon fumes were pretty bad. i am sure that i tripped the light due to that. anyone know how i can reset it with out a lot of cost and ordering a reader for the computer.?????
aisurffish is offline   Reply With Quote
Old 03-09-2008   #2 (permalink)
superfour's Avatar
The standard answer is to run the bike till the fan cuts in.Let it run until it stops and then switch off.Do this four times and the light shouldn go out.The other answer is to take it to your dealer and have them connect you up to their computer.This will tell you why the light came on,and allow them to turn it off.
Currently riding a black Tiger 955i
Stuart
superfour is offline   Reply With Quote
Old 03-09-2008   #3 (permalink)
man that seems really weird and very time consuming but hey ive done crazier things. lol!!!
Old 03-09-2008   #4 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Airsurf, it's not the carbon that would have tripped the light, more likely the flat battery.
I've had mine come on a few times, but don't worry about the three times starting sequence. I just check my oil and coolant is correct, and that the bike feels right when it's running and then ride it normally. If the light fails to go out after the third time you start it, then take it to the dealer to check the error codes. You'll find that they shouldn't charge you to hook up the gameboy, unless they're gougers. It will tell you what the fault code was.
Mick
My Album
miker is offline   Reply With Quote
Old 03-10-2008   #5 (permalink)
thanks mike will do
Old 03-10-2008   #6 (permalink)
Favorite Bike: 2003 Triumph Daytona 955i
ga_skyline_rydr's Avatar
Other Motorcycle: 1993 Honda XR 650 L
Saw this thread and me having the same problem with the same circumstance on my daytona the responses are very helpful to me. The tona wouldn't start in the cold this morning, so probably ran the battery rather flat and now have the check engine light on. So I will follow the advice here since the tiger and tona are similar, thanks again.
ga_skyline_rydr is offline   Reply With Quote
Old 03-10-2008   #7 (permalink)
this is the first triumph i have owned. i am sure i will be a regular to this site to get great response and info.
Old 03-12-2008   #8 (permalink)
hey how about that no more light, great info guys
check engine light jinxx1313 Triumph SuperSports 10 05-24-2008 05:14 AM
Check Engine Light HTH13 Tiger Workshop 5 03-08-2008 01:01 PM
check engine light came on Euro Speed Triple Forum 13 01-13-2007 02:39 PM
check engine light robbo1847 Modifications & Workshop Talk 4 07-17-2006 03:35 PM
Check engine light Speed Triple Forum 1 07-02-2004 01:19 PM
