Old 03-09-2008   #1 (permalink)
Favorite Bike: Triumph America
Cool Newbie tips on bike check up
Just bought a 2003 Tiger 955i and need help to do the routine daily/monthly check ups on the bike. Anybody know where to seek help/advice, a club or somewhere similar where people can physically show me?
Things I need to learn how-to are:
• Engine oil cooler leaks
• Engine oil filter renew
• valve clearances
• engine ecm - stored dtc΄s
• idle oc level
• throttle cable
• cooling system
• coolant level
• fuel system leaks
• forks leaks/operation
•brake fuel levels
• brake pads wear levels
• tyre pressures
• clutch cable
Regards, Espen
Illustrator and designer: www.espenlauritzen.com
Espen36 is offline   Reply With Quote
Old 03-09-2008   #2 (permalink)
Favorite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1955 Velocette Viper
Never heard of anyone having these - if yours does I would suggest it's damaged. I always just walk round the bike before a run looking for fluids underneath it, make sure it's sitting square etc.
You just need the special adaptor available from a Triumph dealer or triumphonline etc. Pretty easy to use.
• valve clearances
These only need checking every 12K or so. It's a bit of a hassle but not difficult. If they need adjusting, there's a tool available from the States from someone here which (even with shipping) is much better than the Triumph one.
You need Tuneboy to check these - do a search here. Aroiund £200 but an excellent bit of kit.
• idle oc level
I take it that this is O2 level - again can be adjusted via the A/F ratio using Tuneboy but I don't think many people actually bother checking the level.
• throttle cable
I lubricate mine about once a year using the time-honoured plasticine funnel method.
• cooling system
Yours may have the hoses to the expansion tank crossed over - mine did - again have a search here and you'll find useful info.
• coolant level
Keep it low rather than high in the expansion tank otherwise it'll spit some out.
• fuel system leaks
Usually due to failed connectors - otherwise damaged O rings on the connectors. These should be changed every time you remove the connector in theory but if you're careful you don't have to. I use a thin smear of vaseline to help it in(!) They're cheap enough though.
If you have a leak then you need new seals.
•brake fuel levels
You have a window to check this on the front - remove the reservoir cap on the rear.
Usual 3mm or so although I like to change mine before that.
• tyre pressures
As standard for me.
• clutch cable
Again I lubricate mine once / year to keep it sweet although people tell me I shouldn't.
If you plan to do much work yourself it's well worth getting the proper Triumph workshop manual - often come up on ebay for £30 - £40. There's a chap selling scans at £4.50 which are good enough for most things.
HTH
Ian
2004 Tiger 955i
1955 Velocette Viper.
iansoady is offline   Reply With Quote
Old 03-09-2008   #3 (permalink)
Thanks
Thanks for quick response. I am gonna look into this
Old 03-09-2008   #4 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Espen, welcome to Tiger land....
Iansoady is on the money with his comments, if you have any problems.
If you're after general maintenance schedule and how to do each check, you can get the genuine Triumph manual, or the Haynes manual for Triumph Triples. That's what I have and it works for me. Take your time, read all the relevant parts and in no time you'll be an expert!
Most of the maintenance is fairly simple and easy to do, even for someone who's never had to do it before.
Mick
My Album
miker is offline   Reply With Quote
Travel (non bike sadly) to Tassie - Tips? nmendham Sprint Forum 2 01-03-2008 04:18 AM
Newbie Question: Cornering Tips Plse? DeanRider Biker Hang-Out 31 01-16-2007 07:10 PM
Newbie needing Speed Four Buying & tuning Tips critch Triumph SuperSports 5 01-01-2007 06:36 AM
Bike washing tips from moi roadkill Speed Triple Forum 3 08-09-2006 12:08 AM
Cleaning the bike...tips and tricks to share??? Dukester Modifications & Workshop Talk 16 08-16-2005 01:10 PM
