» Log in
User Name Not a member yet?
Register Now!
  #11 (permalink)
Old 03-07-2008
hi, change gasket and used a liq gasket backup just incase on the thorottle bodies, no change,
going to have a look at the O rings on the injectors to see if any has leaked.
  #12 (permalink)
Old 03-09-2008
Ok so now I’ve checked all of the above,
would loose exhaust joints cause any idle problems?
need help to sort this or its the angle grinder to the beast
  #13 (permalink)
Old 1 Week Ago
Newbie
Favorite Bike: '02 Tiger
Similar issue on an '02 Tiger
I'm having a similar issue with my '02 Tiger - rough idle, misfire, won't run; diagnosed as a vacuum leak at cylinder three on the throttle body/head interface. It appears that a gasket replacement will fix the prob; I'll let you know what we find, especially if it doesn't fix the problem and there is another approach.
Help! Carb tuning or misfire problem IrlMike Hinckley Classic Triples 11 03-05-2008 09:18 AM
T595 Idle problem micktriple Modifications & Workshop Talk 0 09-26-2007 11:41 PM
Idle problem gbc The Rocket Science Forum 2 09-18-2006 04:10 PM
Idle problem solved rktmn3 The Rocket Science Forum 6 03-09-2006 05:47 PM
T595 idle problem Pipes Daytona Deliberations 0 06-23-2005 07:40 AM
