Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
Old 02-28-2008   #1 (permalink)
Favorite Bike: Triumph Tiger
DobroDog's Avatar
Broken fuel coupling
The plastic fuel line coupling that attaches to the gas tank was leaking and in my investigation of the leak it snapped of at the tank. In an earlier thread on this topic someone posted a link to the Colder company as the probable source for the original connections.
http://www.colder.com/Home/tabid/36/Default.aspx
The connectors look like what come on the tiger
In looking at the Colder site I found what appears to be a metal version of the plastic fitting.
http://www.colder.com/Products/Metal...x?ProductId=18
Anyone have experience with this part?
DobroDog is offline   Reply With Quote
Old 02-28-2008   #2 (permalink)
How old is your Tiger.? The fuel couplings are part of a recall and replace by Triumph.You can run your VIN number through the technical section of the official Triumph website or have your dealer check it out. Apparantly they replace the plastic with metal.
MrGromit is offline   Reply With Quote
Old 02-28-2008   #3 (permalink)
DobroDog's Avatar
The Tiger is a 2001. What I have read in other posts is the recall is for the plastic part that was attached to the fuel line and did not cover the part that attached to the fuel tank. The parts of the coupling that are attached to my fuel line are metal, so I beleive they have been changed already.
I discovered the leak at 1 am this morning so I have not had a chance to call Triumph yet. We will see what they have to say in a few hours when I call them.
Tim
Old 02-28-2008   #4 (permalink)
DobroDog's Avatar
Just spoke with Triumph and the recall does not cover the female part of the coupling that screws into the Fuel Tank.
Their reasoning is that it is no evidence to support that the part is defective. The failures result because when re-installing the tank the part is bumped against the frame.
There is a metal replacement part that I am tracking down. For those of you afflicted with accute or chronic Farkllitis; I will post the source and part information when I find it.
Tim
Old 02-28-2008   #5 (permalink)
I seem to remember "Ma's Cycles" or similar sells them.
Kiwi Tiger is offline   Reply With Quote
Old 02-28-2008   #6 (permalink)
DobroDog's Avatar
Called Ma's and they remember when they carried them years ago
They were very helpful, spent time looking on other websites for me. I can see why people like working with Ma's; good people.
Tim
Old 04-28-2008   #7 (permalink)
Newbie
Snapped Fuel Connectors.
My first contribution to the site - just so happens I had cracked fuel connectors at the neck of the fitting. Real pain to get out the plastic remains. I will replace the plastic fittings on my 2003 tiger once I know the part no of the colder co. replacement. Anyone have an idea?
Cheers Everyone
tommytool is offline   Reply With Quote
Old 05-12-2008   #8 (permalink)
mff
Gas Tank quick discount fitting leaking
Mine is leaking also- looks like a very dangerous problem- How many have had this happen?
MFF
mff is offline   Reply With Quote
Old 05-12-2008   #9 (permalink)
AVM
Replace the o-rings and see if that fixes the leak. Only takes a small nick on one of the o-rings to make it leak and they're cheap at the dealer. I always keep a few on hand.
AVM is offline   Reply With Quote
Old 05-20-2008   #10 (permalink)
Newbie
Favorite Bike: Ktm Supermoto
Other Motorcycle: '03 Tiger
DobroDog (or anyone who knows) -did the Colder couplings fit/work on your tiger? I discovered the original plastic female had cracked at the plate this weekend when I awoke to a garage full of fumes and a gas puddle (after filling the tank on Friday).
How hard is it to get the cracked female out (there must be some joke there)?
I'm shocked that with the number of failures reported, that Triumph did not replace both plastic parts with metal during their recall.
Thanks for any help or insights,
Blake
VATIGGER is offline   Reply With Quote
Broken Spokes ? Oh not, how about broken Rims BorgCymru Tiger Chat 4 12-03-2007 06:37 PM
Broken Dry Break plug on fuel tank... MarioG Speed Triple Forum 4 05-15-2007 02:17 AM
fuel fittings problem (tank fitting broken) - advice needed txsport06 Triumph SuperSports 3 08-07-2006 12:01 PM
dreaded fuel tap broken- possible cause of my probs!??! johnnycactus T3 Sport / Touring Forum 5 07-25-2006 09:09 AM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 09:23 AM
